Old 04-02-2015, 09:23 PM   #1
daveymc29
daveymc29's Avatar
Default 42 - 48 rear brakes
Here's my problem. I have 42 to 48 rear brakes on my Model A. Since I had over a 100 books on old Fords and cars of all breeds, I donated the lot to the Auto Museum at Black Hawk. Along with that donation went all my knowledge of the brake system on my car. Now I'm wondering the proper direction to turn the adjusters to take up some alack? I have found that if I rotate them far enough in either direction I can lock them up. I'd rather not pull the hubs as the lining are only a year or two old, not a whole lot of miles and the less I pull hubs the happier the axle threads seem to be. Thanks for any tips.
daveymc29 is offline   Reply With Quote
Old 04-02-2015, 10:07 PM   #2
rich b
rich b's Avatar
Default Re: 42 - 48 rear brakes
Put the wrench on the adjuster so it is pointing away from the axle, and push down, then you don't have to think about the actual direction.
rich b is offline   Reply With Quote
Old 04-03-2015, 11:59 AM   #3
john in illinois
john in illinois's Avatar
Rich, Thanks,good tip. Now I won't have to look it up every time before I adjust.
John
john in illinois is offline   Reply With Quote
