Old 03-31-2015, 10:14 PM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Are these ammeters original?
Here are pictures of my 2 ammeters. I think they are both original, but they are not identical. They are certainly better quality than repos i've had.
Can anyone confirm that they are indeed original? Why are they different?
Thanks, Neil
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 03-31-2015, 10:21 PM   #2
Greg Jones
Greg Jones's Avatar
Default Re: Are these ammeters original?
Look original to me. The one on the left looks to possibly be 26-27 Model T which had a wider flatter bezel than the Model A.
Greg Jones is offline   Reply With Quote
Old 03-31-2015, 10:24 PM   #3
Tudortomnz
Tudortomnz's Avatar
Original.
Tudortomnz is offline   Reply With Quote
Old 03-31-2015, 11:57 PM   #4
P.S.
Need to see the insides to be certain, but I don't think the one on the right is an original.
The nuts on the back do look original on both.
P.S. is offline   Reply With Quote
Old 04-01-2015, 12:12 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
Originals should have the brass bus bar paint black, so you don't see the brass through the slot on the front. They both look original but I can't expain the brass showing. They are easy to take apart if the needle needs to be straightened. I always use a toothpick to put a drop of heavy oil or very light grease on each of the two pivot points. Original meters when cleaned and lubed are accurate. Be sure the special nuts on the back are tight.
Old 04-01-2015, 09:31 AM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Tom,
A couple of years back, The Restorer had an article on restoring ammeters, including how to replace the buss bar insulators.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-01-2015, 09:39 AM   #7
d.j. moordigian
d.j. moordigian's Avatar
This one is original. The other could be used if you change the bezel, face and paint
the inside of the Ammeter..
As an aside,..Tom should post some photos of his meters apart.....great photos!
d.j. moordigian is offline   Reply With Quote
Old 04-01-2015, 09:45 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
I thought all the original meters had the circular nuts with the slot?
Old 04-01-2015, 09:52 AM   #9
stouchton
stouchton's Avatar
I was actually going to ask a question on this topic!
The judging standards seem to imply the original meters did not use white ink, that the lettering and scale were simply the base metal (with nickel plate?).
I could never find a meter that looked this way - perhaps I am reading the judging standards wrong?
stouchton is offline   Reply With Quote
Old 04-01-2015, 10:48 AM   #10
d.j. moordigian
You could be correct!
The face and glass needs to be cleaned,...to be sure.
How about this......
Original Ammeter ( 1 2 3 view all)
Old 04-01-2015, 12:30 PM   #11
msmaron
msmaron's Avatar
Take a look....here is an original
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
