Old 03-31-2015, 06:40 PM   #1
DadOfTwo
DadOfTwo's Avatar
Default I think I found my electrical problem
Isn't there supposed to be a terminal block here somewhere?
'29 standard coupe project build thread
DadOfTwo is offline   Reply With Quote
Old 03-31-2015, 06:42 PM   #2
TinCup
TinCup's Avatar
Default Re: I think I found my electrical problem
Well it helps. Wow 25 cent fuse would have helped here.
TinCup is offline   Reply With Quote
Old 03-31-2015, 06:56 PM   #3
DadOfTwo
DadOfTwo's Avatar
I'm a big fan of fuses.
Old 03-31-2015, 06:49 PM   #4
Jwilli
Jwilli's Avatar
Lucky that the car didn't burn up.
Jwilli is offline   Reply With Quote
Old 03-31-2015, 07:16 PM   #5
Bob C
Isn't that it on top of the head
Bob
Old 03-31-2015, 07:25 PM   #6
DadOfTwo
DadOfTwo's Avatar
Bob
Actually, it's busy freezing up the throttle crossover linkage thingy. What's the proper name?
Old 03-31-2015, 07:22 PM   #7
mshmodela
mshmodela's Avatar
Yeah, time to toss the wire out and start from scratch...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 03-31-2015, 08:49 PM   #8
DadOfTwo
DadOfTwo's Avatar
Yeah, and I keep thinking "since I have to start over any way..."
Old 03-31-2015, 07:30 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
The year I tought auto mechanics at the Vo-Tec one of the other teachers told the students to put a nail in the fuse box to find the short. Not to smart to burn up wires to find a short. It can be easily done using a flasher and compass. Replace the fuse with a flasher and light bulb, or resistor, then run the compass along the wire harness. The pulse of current will make the compass needle move. Once you go past the short, the current won't be flowing and the compass won't move.
Old 04-01-2015, 08:59 AM   #10
bobusnick104
bobusnick104's Avatar
When I read something from Tom Wesenberg, I know I'm going to learn something. On behalf of all the Barners like myself, Thanks.
It's only money, we'll make more tomorrow.
bobusnick104 is offline   Reply With Quote
Old 04-01-2015, 11:00 AM   #11
1930artdeco
1930artdeco's Avatar
Hi Tom,
For us electrically impaired folks could you post a picture of the 'flasher and light bulb'.
Thanks,
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 04-03-2015, 12:36 AM   #12
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Originally Posted by 1930artdeco View Post
Hi Tom,
Thanks,
Mike
It's just a flasher in line with a bulb. The reason for the bulb is so it will light in case of a dead short saving the wiring.
A cheap compass will work easier then an expensive liquid filled unit.
Old 04-03-2015, 08:09 AM   #13
Tom Wesenberg
Hi Tom,
Thanks,
Mike
The bulb is to keep the full current of a dead short from going through the flasher contacts. Use a headlight bulb or brake light bulb to give enough amps to make the compass needle deflect. Just wire the bulb in series with a 2 prong flasher and clip it to the fuse holder contacts. In place of the bulb you could use a 1 to 1 1/2 ohm resistor rated at 50 watts. These can be bought on ebay for about $4.
http://www.ebay.com/itm/1-50W-Alumin...item3ce3484c4b
Old 04-01-2015, 10:52 AM   #14
MrBruce
MrBruce's Avatar
Looks like time to re-wire and freshen it up a bit. Lucky it didn't do more damage.
MrBruce is offline   Reply With Quote
Old 04-01-2015, 11:25 AM   #15
Mitch//pa
here is my fancy setup
Old 04-02-2015, 08:51 PM   #16
burner31
burner31's Avatar
Holy guacamole
Damn near fried your ride
I agree with the fuse...INSTALL ONE
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 04-02-2015, 09:06 PM   #17
daveymc29
daveymc29's Avatar
Or spend a bit more and put in a circuit breaker I have been known to create a short and pop a fuse so the circuit breaker saves me going to the store for another box of fuses and also from little side trips to the parts vendors for parts like what you will now require, though it is not stock so a real purist wouldn't like it with a fuse in the system.
daveymc29 is offline   Reply With Quote
Old 04-02-2015, 11:49 PM   #18
jax55
jax55's Avatar
I started with a circuit breaker worked great while I sorted out my electrical system.
Then first time I drove the car it quit due to the breaker failing. Bought another to replace it , it was bad right out of the box. I am going back to fuses. and will put together a flasher for short circuit testing.
jax55 is offline   Reply With Quote
Old 04-03-2015, 10:23 AM   #19
DadOfTwo
DadOfTwo's Avatar
Thanks for the comments and suggestions!
Definitely going to incorporate a fuse.
On that note, I've got a lot of rewiring to do. Lots of shody electrical splicing done over the years. Plus going to add a second tail light, turn signals, and probably go 12v.
Since I need all new harnesses, I'm weighing the idea of a modern style wiring harness with a hidden but accessible muti-fuse block.
Anyone done it, or seen it done?
Old 04-03-2015, 10:52 PM   #20
Mike V. Florida
Yea, Hot Rodders do it all the time, modern looking wire and fuse block.
Why the decision to go to 12 volts?
If your heart is set on the hidden fuse block route, may I suggest that you look into using the original style wire that is available from the vendors, using that style and wire in the fuse block.
It's your car to do with as you please.
