Old 03-26-2015, 03:09 PM   #1
tiger.1000
Smile Ford B Zenith....Success at last !!!
After years of head scratching and pulling Ford B Zeniths apart until I am blue in the face I have finally cracked it !
After all the usual cleaning and poking with bits of wire, cleaning the jets with number drills, setting the float level to the correct height and what-have-you, I have now got a carburettor that runs as it should. No skipping, doesn't stall at junctions and accelerates as it should and here's how.
My pal is a skilled clock maker and relies heavily on his ultrasonic cleaner for the removal of years of muck, grit and grime. For the sheer hell of it I pulled a Zenith apart this morning and submerged it in his ultrasonic parts cleaning for 30 minutes. I couldn't believe the amount of muck and grit that ended up in the cleaning tank. I repeated this procedure again for good measure, following which I rinsed the Zenith in cold water, blew it out with an air line, then immersed it in thinners for a final rinse and then another blast with the air line.
Reassembled the Zenith, filled the float chamber with petrol, fitted it to the
car, crossed my fingers and made a wish.....lo and behold, not only did the car start immediately it ran without stumbling and idled with the GAV fully closed.
Equipment needed is: One 6.5 litre cleaning tank and 5 litres cleaning fluid.
I think the cleaning fluid is water with a couple of shots of "truck cleaner"
added to speed up the process.
Give it a go ! I worked for me !
tiger.1000 is offline   Reply With Quote
Old 03-26-2015, 03:57 PM   #2
Mart
Mart's Avatar
Default Re: Ford B Zenith....Success at last !!!
Well done!
That's a great result!
Mart.
Old 03-26-2015, 04:35 PM   #3
tubman
tubman's Avatar
Sounds great! Hmmmmm, I bought my wife an ultrasonic jewelry cleaner for Christmas last year. I wonder..... Ah, I guess not.
tubman is online now   Reply With Quote
