#1 |
I'm tired of my stock dash gauge reading so much lower than my mechanical gauge. I took the gauge mechanism out and see two adjustments inside that can be made. Has anyone every adjusted that gauge and know how? Here's the inside:
![]() You can see two sets of teeth overlapping a hole at 1:00 and 8:00. Which do I adjust and which way?
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
