Old 03-24-2015, 07:26 PM   #1
FrankWest
FrankWest's Avatar
Default how to tighten radiator cap
What is the proper way to tighten a radiator cap fit. I have an original cap that fits ok but I think it should be a little tighter.
What is the proper layering of metal spacers and non metal spacers?
FrankWest is offline   Reply With Quote
Old 03-25-2015, 01:14 PM   #2
FL&WVMIKE
FL&WVMIKE's Avatar
Default Re: how to tighten radiator cap
Find some thicker gasket material.
MIKE (mikeburch)
FL&WVMIKE is offline   Reply With Quote
Old 03-25-2015, 01:45 PM   #3
G.M.
You have to drill the rivet out and replace it with a SS slotted RH screw, LW and nut.
Make a new gasket out the red rubber material in the local hardware store. G.M.
www.fordcollector.com
Old 03-25-2015, 01:48 PM   #4
Tim Ayers
G.M.:
What is "LW"?
Tim
Old 03-25-2015, 02:06 PM   #5
Jay in Mass
I'm willing to bet that LW means lock washer.
Jay in Mass is offline   Reply With Quote
Old 03-25-2015, 02:38 PM   #6
DavidG
DavidG's Avatar
G.M.
Original '32-'34 caps aren't riveted together. The various out-of-sight components are held in place with a screw and lock washer that threads into the underside of the cap casting (zinc die cast).
It would seem that your reference is to a '35 and up radiator caps.
Old 03-25-2015, 03:01 PM   #7
Tim Ayers
Aw, yes. I didn't have my smart pills yet.
Old 03-25-2015, 08:38 PM   #8
fourfords
fourfords's Avatar
My original radiator cap fit very loose. I have a sheet of thin rubber gasket material. I simply cut the material and placed it on the the cap. I put a finger tip of oil on the material to help the cap go on and off easier. solid and not too snug.
fourfords is offline   Reply With Quote
Old 03-26-2015, 05:16 AM   #9
Tim Ayers
There is a member here who is selling a supposed NOS kit to refurbished an early rad cap.
Old 03-26-2015, 03:11 PM   #10
johnh7
johnh7's Avatar
It is interesting to see how each of us modify the radiator cap.
John
Live for today, but save for tomorrow!
johnh7 is offline   Reply With Quote
Old 03-26-2015, 03:45 PM   #11
Bruce Lancaster
Ford sold only complete cap assemblies and separate gaskets...nothing else seems to have been serviced. Drake has a nice kit for early V-8's containing everything except the casting.
Bruce Lancaster is offline   Reply With Quote
Old 03-26-2015, 04:39 PM   #12
Bruce Lancaster
Well, the kit for sale is not Drake stuff, and theguy selling it is known as a mighty parts hunter...so likely really Ford!
