Old 03-23-2015, 08:04 PM   #1
Muddyfeet
Default Resistor for 6 volt points
Do I need a resistor in a 6 volt points system. Late thirty's flathead dual point old style coil.
Muddyfeet is offline   Reply With Quote
Old 03-23-2015, 08:12 PM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: Resistor for 6 volt points
Yes, it usually on the inside of the firewall, It cuts the 6 volt down to 3-1/2 to 4 volts. Most Ford parts places have them, maybe Napa. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 03-23-2015, 08:31 PM   #3
Muddyfeet
Thanks for the info.
Old 03-23-2015, 09:14 PM   #4
JSeery
JSeery's Avatar
The whole panel looks like this, a fuse for the lighting circuits and the resister for the coil. Power from the starter solenoid goes to one side of the fuse (Y). This is also the connection point for generator (YB), the ignition switch (YB) and the cigar lighter (YG). The other side of the fuse connects to the lighting switch (YR) and the pillar lights switch (B-BL). The ON side of the ignition switch connects to the resister (BR) and the gauges (BG). The other side of the resister connects to the coil (R).
(Y) Yellow
(YB) Yellow/Black
(YG) Yellow/Green
(YR) Yellow/Red
(B-BL) Black/Blue
(BR) Black/Red
(BG) Black/Green
(R) Red
Old 03-24-2015, 04:31 AM   #5
koates
More specifically you require the correct FORD resistor, part number 18-12250 and not just any old (or new) ignition resistor from your local parts store. 6 volt ford V8 ignition coils from 1932 to 1948 are designed to operate in series through the resistor on 4.5 volts with the engine running. Typically the system voltage with engine running and generator charging (engine revved up some) is around 7.5 volts. Regards, kevin.
koates is offline   Reply With Quote
Old 03-24-2015, 10:14 AM   #6
51504bat
51504bat's Avatar
I just converted my '39 p/u to 12 volts and I have the original 6 volt resister assembly that was working when removed. PM me if interested.
Tim
Old 03-24-2015, 04:54 PM   #7
supereal
supereal's Avatar
The correct Ford ignition resistor has an element made of nichrome wire, such as in old toasters. As the voltage in the system increases, the winding heats up, increasing resistance to keep the voltage to the coil in the 3-3.5 range. Ordinary voltage droppers don't do this, usually resulting in burned points. If you convert to 12 volts, have the coil rewound so you can eliminate the resistor on them firewall.
supereal is offline   Reply With Quote
