Old 03-22-2015, 10:34 AM   #1
denns1989
denns1989's Avatar
Default Resistor Unit / Coil Resistor 6 Volt System
Greetings Again
I searched & didn't find a clear answer for my current inquiry.
My car with a 1949 - 53 8BA 6 volt pos ground system didn't have a "resistor unit" as it's called in the manual or "coil resistor" as it is often referred to... I have rewired the car & just wanted to ask a couple questions.
I'm aware of the general rule that a 1.3 ohm coil is used on a 6 V system, however they were also used on 12 V system with a "ballast resistor" or you can use a 3 ohm coil direct on a 12 V system.
I think I understand that the coil resistor was designed to supply a full 6 volts when cold & then drop the voltage to roughly 4 volts so not to damage the ignition system? But why only on Fords when most other 6 V systems use a 1.3 ohm direct ?
My car had a "1.3ohm" coil without a "coil resistor" & I have to assume it worked, is the "coil resistor" only required when using an original coil that has a different internal resistance ?
I can just order a coil resistor & "original" coil but I wanted to understand if this is only necessary when using an "original coil" for the car or can you just use a standard 1.3 ohm coil & forget the coil resistor... if I upgrade to Petronix, they state to use on "non ballasted" systems with stock coil (not high voltage)... so once again I would assume this means with no "coil resistor"
Hope I'm making sense, thanks in advance
denns1989 is offline   Reply With Quote
Old 03-22-2015, 12:57 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Resistor Unit / Coil Resistor 6 Volt System
Use the Bosch blue # 0012 coil . Its a 3 ohm coil , no resistor is needed..
http://www.amazon.com/s/ref=nb_sb_no...osch+blue+coil
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 03-22-2015, 04:11 PM   #3
denns1989
denns1989's Avatar
ahhh the Bosch Blue - same as I have on my MG Midget well regarded coil - Perfect !
So even though it's a "12 volt" coil it's fine to use direct on a 6 volt system ? Just wanted to be sure, makes sense though, total resistance will be the same as it would be with a resistor & 1.3 ohm coil.
Thanks
Old 03-24-2015, 07:46 AM   #4
denns1989
denns1989's Avatar
I believe the Bosch Blue was recommended if I had a 12 volt system ?, but for a 6 volt system the 3 ohm will be to much ? (only 2 amps on 6 volt)
Further research indicates that the coil resistor is only needed if using an "original" pre 48 coil that has an internal resistance that is less than 1 ohm (maybe 0.8?) But if using a regular "round can" coil no coil resistor is needed, just a 1.3 ~ 1.5 ohm coil typically referred to as a 6 volt coil (or 12 volt coil that needs an in line resistor.)
Old 03-24-2015, 07:53 AM   #5
BUBBAS IGNITION
Correct ...........
[email protected]
Old 03-24-2015, 08:08 AM   #6
denns1989
denns1989's Avatar
Perfect ! Thanks Again for your help !
Old 03-24-2015, 04:58 PM   #7
supereal
supereal's Avatar
Most of the round 6 volt coils have a built in resistor so no external one is required. Many vehicles in the fifties had a "ballast" resistor so the ignition switch or solenoid could bypass it to give the engine better starting with higher voltage while the starter was running.
supereal is offline   Reply With Quote
Old 03-25-2015, 11:48 AM   #8
tiquer
Bubba PM ed you
tiquer is offline   Reply With Quote
