Old 03-21-2015, 07:26 PM   #1
GT66PONY
Default 1928 Closed cab sediment bowl
Ok so in my parts that came with my truck are two sediment bowl Setups
The new glass one and the old cast iron one ! Witch one should I use and why??? Starting to put it back togather
GT66PONY is offline   Reply With Quote
Old 03-21-2015, 07:56 PM   #2
Joe K
Joe K's Avatar
Default Re: 1928 Closed cab sediment bowl
Well, first inclination would be to go with the cast iron as this is probable to have been there originally.
But - you may have issues. If the cast iron bowl has had water in it - and frozen - then likely you can find the crack if formed. If you remove the brass plug (keep the lead washer intact if you can as they're not reproduced) you should be able to see a crack. A quick blast with glass beads will bring out the flaw.
If everything seems AOK on the basic structure, then buy a re-build kit and give it a go. You'll know shortly after you put it in service if you have a leak.
If it leaks, then you can keep driving with the glass one until you can find a more original replacement.
Were your truck a 1929, I would say you might use either with originality. More likely later 29 would have had the pot metal thing. (which is probably more practical and reliable than the cast iron - but hey, original is original.)
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 03-21-2015, 08:28 PM   #3
HoarseWhisperer
HoarseWhisperer's Avatar
Lead Gaskets for the sediment bulb are available at Brattons.
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 03-21-2015, 08:40 PM   #4
GT66PONY
as You can see from the photos, original is not real important right now!
I have always been into Muscle cars and this is my first old car.
I want to keep it looking original and not do anything that can not do anything that can not be undone.
Thanks for the info !
Gary
Old 03-21-2015, 10:25 PM   #5
al's28/33
al's28/33's Avatar
I like the look of the cast iron bulb, just remember to clean it out once a year. Mine has never leaked with new gaskets and tight fittings.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 03-22-2015, 12:30 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Ditto
Also with the cast bulb, after you work on the engine you can open the valve and clean the grease off your hands.
Actually it's handy if you need a quart of gas for the lawn mower, and the gas can is empty.
Old 03-23-2015, 02:41 PM   #7
rocket1
In my younger days us guys use to pile in the A pickup and head to the lake we got our grill going by draining some gas out of the tank through the cast iron filter.
rocket1 is offline   Reply With Quote
Old 03-24-2015, 05:04 PM   #8
Hoogah
Hoogah's Avatar
Wow, scarey! Is that how you got your FordBarn name?
Hoogah is offline   Reply With Quote
Old 05-31-2020, 11:40 AM   #9
Boss0144
How do the rebuild parts go in the sediment bulb? I assume that the mesh goes toward the valve on the bottom? And the spring goes on top to keep the mesh in contact with the seat? When I try to assemble it this way, that spring is pretty stiff and it makes it difficult to get the threads on the brass piece started. Just want to know I’m doing it right! Thanks!
Boss0144 is offline   Reply With Quote
Old 05-31-2020, 11:45 AM   #10
DBrer
I like the glass one only because I can see if anything is in it without taking it apart.
DBrer is offline   Reply With Quote
Old 06-01-2020, 06:08 PM   #11
Purdy Swoft
Purdy Swoft's Avatar
I prefer and use the cast iron bulb . I have never had a leak or problem of any kind with the cast iron bulb and prefer the old original look . I found that if a person uses the glass sediment bowl it is best to keep extra gaskets on hand . It is usually necessary to replace the gasket every time that the glass bowl is removed or it will leak .
Years ago I had one of my model As to catch on fire and burn in the drive way because of a leaking glass style sediment bowl . The lead gasket used on the cast iron bulb has never leaked or needed replacement .
Old 06-01-2020, 06:57 PM   #12
chrs1961815
chrs1961815's Avatar
I have had nothing but trouble with the glass bowl. Gaskets leak - neoprene or cork. Never had that problem with the cast iron type which I use now. If your tank is clean you have nothing to really worry about.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
