Old 03-21-2015, 01:30 PM   #1
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Model B upper bellhousing.
The Model B upper part of the bell housing , I don't believe you use the 2 shims on the 2 upper 7/16 bolts like the Model A. Is that correct? ALSO, the serial no. that is stamped on top of this upper bell, ( AB5051551 ) can anyone tell me the year. I think this is an early B engine because it has the crank with no counter weights. Thanks Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 03-21-2015, 03:17 PM   #2
darrylkmc
darrylkmc's Avatar
Default Re: Model B upper bellhousing.
Walt, The Model B upper part of the bell housing , I don't believe you use the 2 shims on the 2 upper 7/16 bolts like the Model A. Is that correct? Yes, B-6400 ALSO, the serial no. that is stamped on top of this upper bell, ( AB5051551 ) can anyone tell me the year. April 1932. . I think this is an early B engine because it has the crank with no counter weights.
Yes again, used until December 1932
Darryl in a very warm and sunny Fairbanks
darrylkmc is offline   Reply With Quote
Old 03-21-2015, 09:04 PM   #3
Walt Dupont--Me.
Thanks Darryl. Walt
Old 03-22-2015, 11:11 AM   #4
Jim Brierley
Shims are used to keep everything aligned. The shims should be the same thickness as the housing-to-block gasket.
Jim Brierley is offline   Reply With Quote
Old 03-22-2015, 12:55 PM   #5
hardtimes
hardtimes's Avatar
Hey Walt,
I agree with Jim B . If you do NOT use a gasket to cover the rear cam area, MAYBE then you could get alignment better without shim, but I use shims on my two Bs.
hardtimes is offline   Reply With Quote
