Old 03-21-2015, 08:18 AM   #1
House of Fab
Default spring perch mounts for quick change banjo with torque tube
City: ashland
State: Va
Price: In add
  1. New Item from Havlir House of Fabrication.
    Here is a spring perch that will bolt/weld on your banjo quick change rear that rotates the banjo to the rear 5 degrees.
    These brackets compensate for the rear axle assembly to rotate towards the rear, allowing the torque tube and driveshaft to align with the transmission.
    125.00 which includes shipping to the lower 48
    Here is a link to the straight up spring perches for standard banjo rear http://www.jalopyjournal.com/forum/t...#post-10827934
    Spring perches are available as 2" wide for Model T spring or 2 1/4" for Model A spring
    The first pic shows the straight up version on the left and the 5 degree version on right.
    This pic shows the standard spring perch for regular banjo with torque tube.
    (notice the wheel cylinder location)
    Now the spring perch with 5 degrees of rotation to the rear.
House of Fab is offline   Reply With Quote
Old 03-03-2016, 07:10 AM   #2
House of Fab
Default Re: spring perch mounts for quick change banjo with torque tube
Bttt^^^^
Old 03-09-2016, 06:30 AM   #3
House of Fab
Bttt^^^
Old 03-13-2016, 06:43 AM   #4
House of Fab
Bttt^^^
Old 03-29-2016, 06:46 AM   #5
House of Fab
Bttt
Old 04-18-2016, 05:37 AM   #6
House of Fab
Bttt^^^
