Old 03-13-2015, 08:44 AM   #1
edgar44
Default odometer not functioning with new Mitchell OD install
After installing a new Mitchell over drive in my 31 Coupe, when I took it for a spin the speedo didn't work. I followed written the instructions. Any suggestions?
edgar44 is offline   Reply With Quote
Old 03-13-2015, 08:55 AM   #2
MikeK
MikeK's Avatar
Default Re: odometer not functioning with new Mitchell OD install
The cable core isn't engaging, either at the back of the speedo or at the 'turtle'. Take the cable off the speedo and see if it turns when you move the vehicle. Take it from there.
MikeK is offline   Reply With Quote
Old 03-13-2015, 09:22 AM   #3
edgar44
Thanks. I will try that and see what shows up.
Old 03-13-2015, 04:23 PM   #4
MAG
MAG's Avatar
Had identical problem with Mitchell installation last week. Unit was shipped with the "key hole" type speedo cable drive adapter. A "square" drive cable adapter fixed the problem.
I suppose one could tell Mitchell what type was needed to avoid the situation.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
