Old 03-12-2015, 01:28 PM   #1
spinelll
spinelll's Avatar
Default Rear Brake Lining Wear
What do you make of this?
I did a brake job last winter and decide to check my work.
I removed the REAR drums yesterday and noticed that I’m getting some real nice even wear on the driver side.
On the passenger side I saw something unexpected. It’s worn fairly evenly along half of the lining. Not the left half or right half but the front half, away from the backing plate.
The attached picture is not my lining. I tried to mock up an image as an example. The area highlighted in black somewhat illustrates my wear pattern.
I'll try to take a real picture.
Thanks
Leo
spinelll is offline   Reply With Quote
Old 03-12-2015, 02:51 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Rear Brake Lining Wear
That indicates to me that the drum is not square inside to outside. It may need to be turned to flatten it out, which should result in even wear.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-12-2015, 02:56 PM   #3
Will N
Will N's Avatar
Or maybe the backing plate is bent?
Will N is offline   Reply With Quote
Old 03-12-2015, 03:38 PM   #4
Patrick L.
Patrick L.'s Avatar
Both shoes ? Or just the leading or trailing ?
I'm wondering about a backing plate, shoe or hardware issue.
Old 03-12-2015, 04:23 PM   #5
Mitch//pa
it would be helpful seeing good quality pics of your own shoes
Old 03-12-2015, 04:48 PM   #6
d.j. moordigian
d.j. moordigian's Avatar
....kinda sounds like the shoe is bent..
d.j. moordigian is offline   Reply With Quote
Old 03-12-2015, 06:49 PM   #7
spinelll
spinelll's Avatar
Here's a better shot. Forget the EBrake.
Also, the bottom lining looks good.
Old 03-12-2015, 06:56 PM   #8
Mitch//pa
when you did the brakes what did that consist of? spelling out what procedures were followed and what was actually done will help immensly. How did the previous shoe wear before the brake job?
Old 03-12-2015, 07:22 PM   #9
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Dudley has it correct in that the shoe is likely bent or the shaft holes are too large.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-12-2015, 08:57 PM   #10
spinelll
spinelll's Avatar
Thanks Mitch
I don't recall anything special about the old lining.
As far as what I did, in no special order:
  • Disassembled everything
  • Removed the backing plate
  • Removed the old linings
  • Cleaned the reusable parts by hand with a brush and spirits
  • Put the backing plate in the oven at 200 for about 5 minutes and then easy off. Wiped it off when cool and then scrubbed it in dish soap and water
  • Put some weld on the track and ground that down
  • The ebrake toggle lever/shaft was frozen. I had to remove that with a cut-off wheel. That was a pain. Replaced it with the one that has the zerk.
  • Cleaned everything with wax and grease remover prior to painting with heat paint. Not sure why I didn’t paint the inside of the plate.
  • Riveted new linings (ebrake also).
  • Arched the shoes.
  • New springs, rollers, pins, adjusting wedge, cam, return spring.
  • Reused the cam shaft.
  • Dressed the adjusting shafts.
  • Reassembled.
  • Spent a lot of time centering the shoes.
The end.
Old 03-12-2015, 09:05 PM   #11
Fullraceflathead
Fullraceflathead's Avatar
The Brake drum may be "Bell Mouthed" from being thin or overheated. It looks like the outer area of the Drum to Shoe contact is less than the inner areas near the hub.
If the drums were checked with a Drum Micrometer and were in size and not out of round or Bell Mouthed then I would think the shoe is bent slightly. Maybe someone in it's past beat down hard on the shoe to install the rivets and bent the shoe.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 03-13-2015, 10:02 AM   #12
spinelll
spinelll's Avatar
In the event the issue is the backing plate, will applying a straight edge to the back of the plate reveal anything or are we taking about very small inconsistencies?
Also, please excuse the overuse of the passive voice.
Old 03-13-2015, 07:03 PM   #13
spinelll
spinelll's Avatar
Is it possible to remove a rear top shoe by just disconnecting the EBrake band and leaving the rest of the carrier.
Old 03-13-2015, 07:26 PM   #14
d.j. moordigian
No,...I would think it would be easier, more accurate, in a lathe.
When you wrote,.."I arced the shoes".
Was that done in a machine? Or was it done with a body grinder?
I still think the shoe is bent, tho....or not sitting square too the
backing plate.
Old 03-14-2015, 12:17 PM   #15
spinelll
spinelll's Avatar
backing plate.
It was done in a machine similar to the picture.
Old 03-14-2015, 12:40 PM   #16
Keith True
Keith True's Avatar
While it could be a number of things,bent shoe,egged out holes in the shoe,bent backing plate,bent or worn adjuster wedges,I think the simplest things are the most likely.Bent shoe or egged out holes.Swap the bottom shoe for the top shoe and drive it.Then see if your wear pattern changed or stayed the same.If the shoe on the top then wears as the first one did,it will point to a bent adjuster,bent backing plate,or a bent adjuster housing.That housing can have the holes wallowed out by somebody prying a adjuster wedge out of there with a bar.If the top shoe then wears normally,and the lower one keeps wearing as it did when still on the top it kind of points to a shoe problem.
Keith True is offline   Reply With Quote
Old 03-14-2015, 02:29 PM   #17
d.j. moordigian
I'd start looking at the ends of the shoe and how it sits on the backing
plate. Have someone push on the brake pedal, gently , and watch
how the shoes move...
Old 03-14-2015, 03:27 PM   #18
edmondclinton
Judging by the location of the chalk line it looks dark in places on both sides instead of just all on one.
The picture is not real clear on my computer screen but the wear doesn't really look that odd to me. Does the car stop well?
edmondclinton is offline   Reply With Quote
