Old 03-11-2015, 02:32 PM   #1
Ole Lou
Default 32 Windshield frame disassemble
Having trouble getting screws out to disasemble windshield frame on 32 5-window. Have soaked off and on for months with kroil and blaster. Have tapped, hammered and even used a small hand held impact to no avail
Any other suggestions
Ole Lou is offline   Reply With Quote
Old 03-11-2015, 02:45 PM   #2
rockfla
rockfla's Avatar
Default Re: 32 Windshield frame disassemble
Sometimes I find that if you try tightening them to get It to move they will break loose. Then loosen it, worth a try if you haven't already
Old 03-11-2015, 02:48 PM   #3
Krylon32
As a last resort, drill and re tap.
Krylon32 is offline   Reply With Quote
Old 03-11-2015, 09:46 PM   #4
L head fan
You might try soaking the frame in a molasses bath. (1 part molasses and 8 parts water). This solution is used to remove rust and I have used it very successfully. Usually, all bolts are easily removed after soaking for 2 weeks. Frame will be rust free also! Pressure wash to remove the molasses residue, and use some After Blast from Eastwood to keep the cleaned metal from flash rusting. GOOD LUCK!
L head fan is offline   Reply With Quote
Old 03-15-2015, 08:38 AM   #5
tradin-tin
Heat the screw with a small torch to expand it, once cool it should come loose.
tradin-tin is offline   Reply With Quote
Old 03-15-2015, 11:46 PM   #6
32 ford barn
I would drill and retap. I have done this a few times with excellent results. Jim
32 ford barn is offline   Reply With Quote
Old 03-16-2015, 12:05 PM   #7
jerseyboy
jerseyboy's Avatar
I second the molasses! I have been able to free up many parts with this method.
Make sure you use feed grade, I bought a jug of molasses that is used to lure deer.
Keep V-8ing and 4-banging!
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
