Old 03-11-2015, 11:22 AM   #1
Rojo
Default She's alive again after a long sleep...
After sleeping for almost 15 years, my '29 Tudor woke up again yesterday! She couldn't have recovered from that rest without a lot of help from folks on this forum....I have read every post back to 2010 and it's unbelievable how much great advice and information can be found here. After timing Marco's way, new oil, and a few new ignition parts, she's running fairly well...I still have to open the GAV about a turn and a half after she's warmed up to allow use of the throttle for a smooth acceleration but when attempting to set the idle, the idle mixture screw doesn't seem to have any effect even when screwed fully in. Sure would appreciate any suggestions at this point....I'm so excited to have the family A running again and will never let her sit like that again! It's time to get her off these jack stands and hit some of these Texas Hill Country roads to add a few more miles on her clock...32,457 original miles now. Thanks to everyone who has helped and encouraged me....sure I will have a bunch of new questions now that she's running!
Rojo is offline   Reply With Quote
Old 03-11-2015, 11:51 AM   #2
Brentwood Bob
Default Re: She's alive again after a long sleep...
The carb needs a cleaning. Start with the fuel supply. Likely stuff in the gas tank is the root cause. Bob
Brentwood Bob is offline   Reply With Quote
Old 03-11-2015, 12:09 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Good common sense thinking, Bro Bob,
A pencil filter, a total clean delivery system, a GOOD carb. overhaul, new points & plugs, & it'll run well!
NO NEED TO OVER-COMPLICATE IT!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 03-11-2015, 12:39 PM   #4
Rojo
Thanks! I cleaned the tank before starting, installed a pencil filter above the fuel shutoff valve, new points (.022), plugs (Champion [email protected]), new rotor and body (.025 rotor /body clearance), new condenser, coil,and disassembled the Zenith 2 and cleaned and blew out all the orifices (I think!) Maybe she just needs to run a little longer before I do anything else. I did notice that I can't speed up the rpm much above a fast idle without the GAV open almost 2 turns. I will recheck the carb....Thanks for the advice!
Old 03-11-2015, 02:48 PM   #5
Brentwood Bob
use tom endy's paper clip procedure. from experience the crap lurks in the idle cercuit, and that is why on a good overhaul you would make sure all circuits are clean. try a soak in lacquer thinner before the paper clip. You have a restriction, and it doesn't take much.
Bob
Old 03-11-2015, 03:40 PM   #6
whirnot
whirnot's Avatar
Definitely sounds like a fuel restriction.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 03-11-2015, 05:16 PM   #7
Rojo
Will try the paper clip technique....thanks!
Old 03-11-2015, 09:36 PM   #8
1crosscut
1crosscut's Avatar
Pick up a gallon can of carburetor cleaner from the parts store. They have a basket inside that is really handy for soaking parts. Tear your carb down and give it a good soak. Wash it up and blow out the passages with compressed air. You can use the cleaner to clean other parts and pieces not necessaraly carburetor.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 03-12-2015, 12:57 PM   #9
BILL WILLIAMSON
After being squeaky clean, a soak in warm vinegar helps get of HIDDEN water/calcium deposits in hidden passages, especially in the idle circuit.
Bill W.
Old 03-13-2015, 12:00 PM   #10
burner31
burner31's Avatar
I know exactly what your talking about, engine coming back to life that is.
One of the best feelings, best days.
That's why I love these cars, every time I start it now takes me back to that glorious day.
Drive and enjoy.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 03-13-2015, 12:29 PM   #11
mshmodela
mshmodela's Avatar
Love the sound of the engine --reminds my of my Late Father's Ford 8N Tractor a bit...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
