Old 03-10-2015, 07:24 PM   #1
tim54889
Default cantancerous cutout
My repop cutout points don't weld together, they make contact when ever they feel like it. I've cleaned them and filed and polished. They will charge sometimes and other times not. What the heck!
tim54889 is offline   Reply With Quote
Old 03-10-2015, 07:28 PM   #2
glenn in camino
glenn in camino's Avatar
Default Re: cantancerous cutout
put a diode in it.
glenn in camino is offline   Reply With Quote
Old 03-10-2015, 07:58 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, either use a good diode cutout or a restored original from Bert's. 800-321-1931
I only use original cutouts.
Old 03-10-2015, 08:24 PM   #4
J Franklin
J Franklin's Avatar
You can try to adjust the points gap a bit closer. A diode would solve the problem.
Old 03-10-2015, 09:56 PM   #5
Clem Clement
Clem Clement's Avatar
Get another one, open it up and restore it. Easy job.
Clem Clement is offline   Reply With Quote
Old 03-11-2015, 02:07 PM   #6
tim54889
Wait a minute! After taking the gen all apart, I tightened one of the brush screws and everything works now!
Old 03-11-2015, 09:33 PM   #7
Ron in Quincy
Ron in Quincy's Avatar
A diode is also good insurance to protect the generator in case the battery becomes fully charged when driving a long distance.
I remember, when I was a young man, my dad would turn on the lights on the Ford if we were on a long drive so the battery would not become fully charged and burn out the generator.
I convert all my cutouts to positive ground diode.
Ron
Ron in Quincy is offline   Reply With Quote
Old 03-12-2015, 07:54 AM   #8
tim54889
Oh, A diode will prevent the battery from being overcharged? I did not know that.
Old 03-12-2015, 07:57 AM   #9
Rowdy
The cutout is to prevent burning up the generator when the engine is off by disconnecting it from the battery. Charging is regulated by the position of the third brush. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 03-12-2015, 09:45 AM   #10
FRANK PKNY
FRANK PKNY's Avatar
A diode would solve the problem. However It is not a voltage regulator! You will still need to monitor your charge, yes you can turn your lights on after a bit to help regulate the charge. You can also add an internal regulator under the removable cover of your stock generator. I have one in each of my stock cars, it's out of sight so if your showing it will not knock off points, unless they disassemble your generator.
FRANK PKNY is offline   Reply With Quote
