02-25-2015, 10:23 PM | #1 |
Transmission Question
Hi, new here, but I've been lurking and learning for quite awhile. I've had my '30 Model A Coupe for about 2 months. The person I purchased it from rebuilt the transmission with all new gears. It makes a slight growling noise in first, and a louder growling noise when I shift to 2nd. The worst is when it's in 2nd and I slow down letting the engine hold the car back. I've never been in or driven another Model A, so I don't have anything to compare this noise to. Is this growling normal?
02-25-2015, 10:57 PM | #2 |
Re: Transmission Question
I want to say yes. But you may be experiencing the "new gear" syndrome - that being that new gears, even a full set from the same source, may come from different manufacturers - and may have um, differences between the gears.
These differences add up to make some noise. I have a mix & match transmission that is made up (I think) of similarly aged gears. It runs ok. Nothing spectactular. But it does have some "wind down" noise when downshifting into second. The rule of thumb I got previously (old Ahooga board) and I guess it still holds is to try to source your gears from a trusted seller (snyders, berts, brattons) and buy them all at the same time and question them as to the source. If not this then try to do as I did and use a relatively consistent set of used gears and try not to change things too much between transmissions. There is a concerted effort to try to "match" gears from the manufacturers. And your source (whomever) should be able to tell you anything he himself might question regarding his gear source. You also don't say what exactly you're using for transmission oil. It may be possible to change oil to a bit stiffer brand and reduce some of that noise. Some "back in the day" have compounded 140 oil with graphite, STP or other additives to attempt to make a slicker, quieter, easier shifting transmission. Sorry to be the bearer of bad news but you may be seeing what there is to see. Certainly experiment with your oil. Resist any thought of putting sawdust into the tranny (it will make it quieter) And comfort yourself with the thought that it will only get better as everything wears together in time. I think of it as encouragement to use your car more. Well, any excuse is a good one. Good luck, Joe K
Shudda kept the horse. |
02-25-2015, 11:08 PM | #3 |
I think in general what you are hearing is normal. I could not stand the whining in first and especially 2nd gear. I would shift to high and probably lug the car just to escape the noise. That's why I installed a 39 tranny, my God what a difference it made in the pure enjoyment of driving this car. No whining anywhere and synchronized gears, I will now motor when I need to in second and its nothing but pure smooth!
dusty |
02-25-2015, 11:31 PM | #4 |
Model A's have spur gears (straight cut teeth) and they do make a little whine, but it shouldn't be bad. My tranny is all original gears and shafts and I use 600W gear oil, and the noise isn't a problem, nor is it loud.
02-25-2015, 11:49 PM | #5 |
The issue of "all new gears" is open to question, especially if said gears came from Argentina or they consist of mixed source gears. It is possible that quality mixed source gears will gradually "wear in" and become quieter with time. If from the former Industria Argentina" or one of the other dodgy sources, they will only get louder with wear.
02-25-2015, 11:56 PM | #6 |
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
02-25-2015, 11:59 PM | #7 | |
02-26-2015, 12:50 AM | #8 |
02-26-2015, 06:49 AM | #9 |
Crank starting by hand.
Joe K
02-26-2015, 07:08 AM | #10 |
drain and refill with the oil from the suppliers so you know whats in there. you may want to do the rear diff also. then just drive her / him and enjoy. watch some old movies with A's in them you'll hear them whine also.
some cars are noiser than others so dont compare that way.. as long as your not jumping out of gear or having any other symptoms then just turn the radio up louder |
02-26-2015, 07:20 AM | #11 |
Ironically, a transmission completely rebuilt using a NOS 'Cluster gear' and gears does not make noise any greater than a modern T-5. Even completely rebuilt ones using Mark gears are very quiet IMHO. So are we to accept the mindset they they all should make noise?
02-26-2015, 08:35 AM | #12 | |
02-26-2015, 10:47 AM | #13 | |
'31 40B '31 68C |
02-26-2015, 11:29 AM | #14 |
Brent - I am not familiar with "Mark" gears. Can you tell me where they are from?
Thanks,
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ |
02-27-2015, 12:55 AM | #15 |
Thanks for all of the replies.
Joe & Mitch--It had 600w in the transmission. On the advice of a semi truck mechanic, I put in 85w-140 gear lube. I haven't really noticed any improvement. But I don't have any jumping out of gear trouble. Joe, Tom, Ursus & Brent--The seller who rebuilt the transmission, got the gears from Bratton's. But he said none of today's gears are as quiet as the original Ford gears. He also said they should get better as they wear in. But other people have said they probably won't get better. I'm also not familiar with Mark gears. Weather permitting, I'll drive it to a MARC pot luck this Saturday, and see what other A owners think. To me, it's a little whine but more of a growl on upshifting, and a growl only on downshifting. |
02-27-2015, 01:25 AM | #16 |
Is it quiet in third? Did you check the shaft and bearing between the input and output shafts? Mine had a couple bad rollers on that bearing when I bought the car, and that little bearing made the car sound like a broken down threshing machine in first and second. That bearing is out of play in third, so if it's perfectly quiet in third, you might need to check that bearing, and the end of the shaft it rides on.
02-27-2015, 01:35 AM | #17 |
Yes It's quiet in third. I haven't been into the transmission; I've only changed the lube.
02-27-2015, 01:45 AM | #18 |
Bratton's has good parts I have gotten tranny gears from them and my rebuilds are quiet.
"The seller who rebuilt the transmission" ........ not all rebuilds are the same. See Tom W's comment. Tom Endy wants you to change out all the bearings; and why not
'31 180A |
02-27-2015, 06:31 PM | #19 |
For those who asked about MARK gears the answer is that MARK Auto Company of Layton, New Jersey is one of the oldest suppliers of Model A parts in the country, having been in business since the late 1950's. They were both wholesale and retail for many years, but in recent years became wholesale only, selling to the retail dealers, some of whom have been mentioned in this thread. MARK has furnished USA made gears for the Model A probably since they began years ago. Any gear they offer that has a flat surface where MARK USA can be stamped bears those words. Beside transmission gears they also offer ring & pinion gears as well as other parts.
02-28-2015, 09:36 AM | #20 |
When we did the sedan we built the transmission using all new USA gears made by Mark Auto. It has been so nice a transmission that when it came time to redo the Phaeton we opted to do the same thing and use all new gears from MARK.
