Old 02-16-2015, 02:45 AM   #1
LizardsA
LizardsA's Avatar
Default Cutout switch: how to stop it from "welding" itself closed?
How does one stop the cutout switch from "welding" its points closed? I file the build-up off, and the car runs fine for a trip or two, then the cutout closes itself at the end of the trip.
Regards
Mike
Johannesburg, South Africa
LizardsA is offline   Reply With Quote
Old 02-16-2015, 02:50 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Cutout switch: how to stop it from "welding" itself closed?
Replace it with a diode.
Is your an original ore reproduction?
What kind of current draw does your car have.
At what voltage do the points close?
Old 02-16-2015, 06:23 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I've never had a problem when using an original cutout. Many of the repro cutouts are junk and the contacts burn and stick. I would only use an original cutout, or a quality diode cutout, such as the one made by A&L.
Old 02-16-2015, 06:43 AM   #4
LizardsA
LizardsA's Avatar
Yes you chaps are correct, this is a repro cutout. I have had problems with a diode cutout as well. As for the questions on current draw, or at what voltage the points close, I don't really know how to measure these - please can you give me advice on this?
Old 02-16-2015, 08:29 AM   #5
Tom Wesenberg
Are you using the stock 6 volt positive ground?
I would adjust the third brush so the ammeter only reads a couple amps. This will keep the battery charged for normal daytime driving, and it will lighten the load on the cutout. If you do a lot of night driving, then you will have to raise the amp setting to run the lights.
Moving the adjustable brush up lowers the amps.
Old 02-16-2015, 10:00 AM   #6
eagle
eagle's Avatar
I bought a voltage regulator from Macs a few years ago and it works great. No more having to adjust the generator for night driving. Replaces the cutout and looks perfectly stock.
eagle is offline   Reply With Quote
Old 02-16-2015, 10:31 AM   #7
raprice22
I also installed a Fun Projects voltage regulator, on my '30 Ford, a number of years ago and it had been working great. It looks just like the cutout and even has the Ford script on it.
Rog
raprice22 is offline   Reply With Quote
Old 02-16-2015, 10:40 AM   #8
tbirdtbird
Steve at Bert's in Colorado has re-conditioned originals which many users here including myself rave about.
The spring on the repops is crappy and loses it temper and then becomes very weak.
I have tried a number of diode cutouts and for whatever reason, they don't seem to like Texas much, I can never get them to work
Tom W from this forum makes a quality EVR which means never adjust the 3rd brush again
'31 180A
tbirdtbird is offline   Reply With Quote
Old 02-17-2015, 03:02 AM   #9
LizardsA
LizardsA's Avatar
Thanks everyone for your help. I'll try and adjust the third brush a little and see if I get better results.
Kind regards
Mike
