Old 02-11-2015, 09:50 PM   #1
Fourdy
Fourdy's Avatar
Default Big bore gasketgasket suffice?
Does the 3 5/16 bore require the big bore gasket or will the standard late gasket suffice.
TIA,
Fourdy
Fourdy is offline   Reply With Quote
Old 02-11-2015, 10:06 PM   #2
Pete
Default Re: Big bore gasketgasket suffice?
TIA,
Fourdy
Much has been written, even lately, on head gaskets both here and on the HAMB.
No matter what your engine bore is, you should check your head gaskets on the individual deck they are going to be used on to see if the fire ring hangs over either the block edge or the head edge.
The fire ring absolutely has to NOT be hanging out in space at any point
or the gasket won't hold.
Some brands work on some blocks. Other brands work on some blocks.
Heads vary all over the place also.
It's not cut and dried.
Old 02-11-2015, 10:44 PM   #3
Henry/Kokomo
Henry/Kokomo's Avatar
My experience is that a 3-5/16 bore DOES require a big bore gasket. FWIW
Henry
Henry/Kokomo is offline   Reply With Quote
Old 02-12-2015, 06:05 PM   #4
Fourdy
Fourdy's Avatar
Thanks for the input
Big bore it is.
Fourdy
