Old 02-06-2015, 11:16 AM   #1
wex65
Default 292 v 312 Y bloock - differences
I pulled the 312 that was in my wife's 55 Tbird for a rebuild over the winter only to find a cracked main cap web.... The fact it was a 312 (ECZ-6015-C block with ECZ caps) meant it was not original to the car.
A buddy helped me out with a block (ECZ-6015-C) which is fitted with EBU caps, meaning a 292. He included the crank.
My question is this. Can everything that was on the 312 (harmonic balancer, rods etc, heads) simply slot straight into the new block?
I assume the differences between the 292 and 312 are just the crank/caps, or is there more?
I laid the two cranks next to each other and do see some differences but I assume that is the 292 v 312 element.
wex65 is offline   Reply With Quote
