Old 02-01-2015, 10:38 AM   #1
RodRocket
RodRocket's Avatar
Default 37 Ford toe in/toe out setting
Front tires scrubbing on outside edge. Measuring front & back of tires, toe in of 9/16" of toe in found. How does this relate to degrees? I've read conflicting suggestions about whether toe in or toe out is better for handling on straight axle Fords, always discussed in degrees. I don't know of a shop that still does front end work on "old" straight axle Fords, so I am trying adjust the front end myself. Any help is greatly appreciated. Thanks, Rod
RodRocket is offline   Reply With Quote
