Old 01-27-2015, 08:54 PM   #1
Flop
Default 1929 Roadster
I don know if this is allowed on here but we are assembling a 1929 Ford roadster from Brookville .
The only original Ford piece being the gas tank . Please pull the thread if it violates the rules
alot of work ahead of us as these pieces dont fit together without alot of doin .
cowl and A pillar are to Ford spec
blasted the gas tank . dash rail was a real bear to get on
full fit
had to modify the brookville brace from A pillar to subframe to actually fit over the body mount holes like ford did
equidistant inner door gaps and the quarter brace put in in this picture .
all and all pretty pleased so far with the way its turning out
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 01-27-2015, 09:20 PM   #2
pooch
pooch's Avatar
Default Re: 1929 Roadster
Flop can you elaborate a bit more about the 'bear to fit' pieces.
I am considering buying some brookville sections.
pooch is offline   Reply With Quote
Old 01-27-2015, 09:27 PM   #3
700rpm
700rpm's Avatar
Looks good. I don't know why this would be disallowed by site rules.
Ray Horton, Portland, OR
Old 01-27-2015, 09:40 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
My experiences are these are hand-built bodies that require massage work. Brookville's employees have jigs, fixtures, and hands-on experience in assembling them. The biggest issue is making sure the sub-rail extensions and the cowl are correctly assembled (in alignment) or nothing fits afterwards. Drawings and an original body to measure off of is a huge help in assembling one.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-27-2015, 10:27 PM   #5
Rowdy
I helped a friend assemble one of these bought un-assembled. All I can say id Thank God for cleco clamps. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 01-27-2015, 11:09 PM   #6
ModelAMike1930
ModelAMike1930's Avatar
Very nice work! I wish it was mine when done..
ModelAMike1930 is offline   Reply With Quote
Old 01-28-2015, 01:51 AM   #7
Skeezixx
Skeezixx's Avatar
Is it live or is it Memorex?
Skeezixx is offline   Reply With Quote
Old 01-28-2015, 02:21 AM   #8
pooch
pooch's Avatar
Seeing brookville do not make new tanks, to have a pristine sandblasted original tank coupled to a brookville body is about as good as it gets .
Old 01-28-2015, 08:00 PM   #9
1931 flamingo
1931 flamingo's Avatar
Flop: How's it feel to work with "new" metal??
Paul in CT
Old 01-29-2015, 07:45 AM   #10
Flop
pooch ... just finessing tweaking and sometimes down right force to get things into ford spec .
brent hit the nail on the head . if you dont have measurements or a car to measure from you are in for a real treat .... now i know what happened with the 32 3 window thats in the shop .
Rowdy yes clamps eveywhere !!! tons of em !!!
1931 i have a brookville 32 3 window in here before this one . it spoils you .
thanks guys !!
412 867 1659
[email protected]
Old 01-29-2015, 11:16 AM   #11
Charlville
Charlville's Avatar
Really interesting.
Probably had similar issues way back when, but as mentioned earlier Henry's boys would also have all the kit, and building a lot of cars a day tends to make things a lot easier
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 01-29-2015, 12:44 PM   #12
JBill
My Brookville body was in primer when I picked it up. I didn't have any trouble with parts fitting. Everything lined up well. That was fifteen years ago, though, so maybe things have changed in the meantime.
JBill is offline   Reply With Quote
Old 01-29-2015, 03:12 PM   #13
pooch
pooch's Avatar
I suppose Ford had the same dramas.
I was surprised to see the original factory pics of the hood tweaking machines a while ago that were posted here.
Old 01-29-2015, 04:06 PM   #14
BRENT in 10-uh-C
I would venture a guess not. There was minor finish work to be done back then but not like now. The differences I believe is dies were constantly being replaced plus the press sizes were much greater at Ford. Think about it, each stamping branch was probably fabricating as many Roadsters in one shift as what Brookville is manufacturing in a whole year. I have been at Brookville on several occasions and have seen how they assemble bodies. There is a lot of hand work that goes into one at Brookville. Back in the day, there was not enough time to be able to spend on hand work.
BRENT in 10-uh-C
Old 01-29-2015, 04:12 PM   #15
BRENT in 10-uh-C
...and speaking of Pressing equipment. Compare the pictures of Fords vs. Antique Auto Sheetmetal's. That is my son standing in front of both.
File Type: jpg SES ARE CAPABLE OF PRESSING THE 200 TONS REQUIRED FOR LARGER BODY PANELS[1]... AND THERE ARE ROW.jpg (53.8 KB, 64 views)
BRENT in 10-uh-C
Old 01-29-2015, 07:19 PM   #16
Flop
your son aged well if hes stamping in 1930 and still looking pretty young now a days !
good pictures Brent !
412 867 1659
[email protected]
