Old 01-25-2015, 01:51 PM   #1
Clem Clement
Clem Clement's Avatar
Default Replacement oil plug for the Model A?
See bottom page - might be useful if it doesn't hit tray or crank?
Oil Drain Plug Repair
• Exclusive patented winged drain plug is used when the oil pan nut or flange is broken or missing.
• Eliminating the need to replace the pan part number 090-080 is a time and money saver for pans with 1/2" to 3/4" or 12mm to
18mm drain holes. Requires no tools to install.
CAUTION:
DO NOT use on Honda or Volkswagen. Make sure threaded bolt will not contact any internal parts before installation. Bolt enters oil pan 1-7/8".
090-080
http://www.dormanproducts.com/catalog/
Clem Clement is offline   Reply With Quote
