Old 01-21-2015, 10:21 PM   #1
scar
scar's Avatar
Question Rebuilding a Tillotson carb.
I'm wanting to rebuild a Tillotson X carb.
I ordered a rebuild kit from Macs.
It came with a new choke adjustment needle.
The diameter was too big to fit into the original
adjustment needle's housing.
I sent the kit back and now I'm going to order a
kit from another supplier. I'm trying to keep from
getting a kit that I can't use again.
Does the adjustment needle housing have to be
changed when replacing the needle, or does someone
make a kit that works with the original housing?
Thanks
scar is offline   Reply With Quote
Old 01-22-2015, 05:24 AM   #2
29spcoupe
29spcoupe's Avatar
Default Re: Rebuilding a Tillotson carb.
I got my kit from Tam's. Everything fit well. John
29spcoupe is offline   Reply With Quote
Old 01-22-2015, 11:25 AM   #3
Willie Krash
Willie Krash's Avatar
Can't get by with a gasket set and needle valve Assembly?
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 01-22-2015, 04:29 PM   #4
Brian T
Brian T's Avatar
The only problem I had was with the float valves leaking down after shut down, I ended up lapping in the old valves, I should have just purchased the main jets and gasket set from Brattons --- $10,50.
If you do not have the Tilly rebuild book this mans website is helpful.
https://sites.google.com/site/mrtexa...ly-carburetors
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
