Old 01-12-2015, 08:50 PM   #1
Jerry Kzoo
Jerry Kzoo's Avatar
Default Puzzling Generator
I have a 3 brush generator that I am struggling to get to charge. I have done the following tests:
It motors in a clockwise direction when a battery charger is put on it. It runs slowly, but not smoothly. Kind of like how the Model A motor turns over - erunh-erunh-erunh
When I put the battery charger on the field coils they draw 4.5 amps
When it is on the engine test stand it will pull in the cutout, but will not show a charge on the ammeter with the engine running at fast idle. I have tested the ammeter with attaching a headlight and it shows discharge and tested another generator with this cutout and it shows charge.
The wire from the generator post to the insulated brush is stiff and somewhat restricts the spring action on that brush, but everything else seems good?? I am stumped.
I appreciate all of your expert guidance and hopefully a solution.
Jerry
Jerry Kzoo is offline   Reply With Quote
Old 01-12-2015, 08:58 PM   #2
RonC
RonC's Avatar
Default Re: Puzzling Generator
Did you flash it?
RonC is offline   Reply With Quote
Old 01-12-2015, 09:29 PM   #3
Joe K
Joe K's Avatar
Confirming that it motors in the direction it charges? (i.e. turns in the same direction as the motor drives it)
This would be clockwise as you look at the front (radiator end) of the generator.
https://www.fordbarn.com/forum/showth...rator+rotation
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 01-13-2015, 01:33 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Sounds like a rebuild is in order. While the motoring test will tell you if the unit is bad (no motoring) it will not tell you if it's good, (they can motor and not charge).
Old 01-13-2015, 04:15 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
If that stiff wire to the insulated brush removes some of the brush spring pressure, it will lower the output. I've seen it happen with generators on my test stand. Even the short wire on the ground brush should be positioned in such a way that it doesn't restrict free monement.
So you have power to pull in the cutout but not move the ammeter. I'd check the voltage at the cutout input and output terminals. At fast idle both should be slightly move than idle battery voltage. Both cutout terminals need to be insulated from the case. If this is the style cutout with 2 screws, then the thicker insulator goes on the output side. Make sure neither screw is too long and shorts to the inside of the cutout. The voltage check mentioned should confirm that.
Old 01-17-2015, 03:51 PM   #6
Tom Wesenberg
What's up with this generator? Any progress?
