Old 01-08-2015, 05:06 PM   #1
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Prussian blue
Can anyone explain how to use Prussian blue? tia
Old 01-08-2015, 05:18 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Prussian blue
Use a small brush, such as the small flat acid brush plumbers use, then wipe a thin coating on the gear teeth. Turn the driving gear back and forth so it wipes across the blue and shows a pattern of contact. You want to see the pattern on the drive side of the teeth, and on the coast side of the teeth. Old Motors Manuals have a section showing how to read the patterns.
Old 01-08-2015, 05:30 PM   #3
Patrick L.
Patrick L.'s Avatar
Prussian blue can be used in just about any machining/checking operation.
Its lightly brushed on and filed, milled, ground or worn off to show contact/noncontact area.
In most automotive stuff I find it tedious. To check tooth contact I use white grease and to check valve face/seat contact I use pencil. These are far easier to remove for recheck after adjustment. But, the blue is fine if thats what you chose.
Old 01-08-2015, 05:37 PM   #4
Jim in Wisconsin
In the shops I used to work in, it was mostly used to play jokes on guys. A little dab on the back side of a knob of his machine and after a while he was blue all over and mad as hell.
Jim in Wisconsin is offline   Reply With Quote
Old 01-08-2015, 05:38 PM   #5
Joe K
Joe K's Avatar
I've used blue, but I like black magic marker better on gearing.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 01-08-2015, 05:53 PM   #6
noboD
Smile Re: Prussian blue
Never seize works good too. I agree with the black magic marker. It is very thin and not as messy.
noboD is offline   Reply With Quote
Old 01-08-2015, 06:30 PM   #7
Terry, NJ
Terry, NJ's Avatar
It's great on eye loupes too!
Terry
Terry, NJ is offline   Reply With Quote
Old 01-08-2015, 06:37 PM   #8
noboD
Commode handles or the front lip of the seat, too.
Old 01-08-2015, 08:20 PM   #9
Anteek29
Anteek29's Avatar
You guys had too much fun
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 01-08-2015, 09:04 PM   #10
Rowdy
I use Dykem as it is a fast drying liquid. Not as messy as blue and wipes off with a little solvent. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 01-08-2015, 11:55 PM   #11
Chuck Sea/Tac
Anyone ever use it to check engine bearing contact?
Old 01-08-2015, 11:59 PM   #12
J Franklin
J Franklin's Avatar
Yes, it shows amount of contact or voids
Old 01-09-2015, 12:55 AM   #13
ian Simpson
As an apprentice that would have got me a three day unpaid vacation.
Ian
ian Simpson is offline   Reply With Quote
Old 01-09-2015, 02:21 AM   #14
colin1928
colin1928's Avatar
That's what it is made for
from back in the day when Babbitt bearings were hand scrapped
I like for checking valve seat contact
colin1928 is offline   Reply With Quote
Old 01-09-2015, 06:38 AM   #15
Patrick L.
Patrick L.'s Avatar
For gags we also used loaded condensers.
Old 01-09-2015, 09:48 AM   #16
Terry, NJ
Terry, NJ's Avatar
Dykem is a great layout fluid but it is actually too thick for a high spot "paint".
It tends to flake off or bunch up in tight (Say, .001 clearance) places. Prussion High spot blue must be nearly all wiped off to avoid having an indication of a contact where none exists. It must be thinly applied.
Terry
Old 01-09-2015, 10:25 AM   #17
Rowdy
It has never caused me a problem as long as it is cleaned off and re-applied between checks if adjustment is needed. Rod
Old 01-09-2015, 12:10 PM   #18
Bob Bidonde
Bob Bidonde's Avatar
Bluing was commonly used to layout parts on sheet metal using a scratching awl and to check contact between rubbing surfaces.
Bob Bidonde
Old 01-09-2015, 02:52 PM   #19
Chuck Sea/Tac
So if the mainline was bored, then you should have 100% contact, and Russian blues basically a waste of time?
Old 01-09-2015, 06:24 PM   #20
Tom Wesenberg
I don't wipe it off, I just brush it to erase the pattern for the next pattern check.
