#1 |
I have a 48 ford truck on it's way. Guy said just recently it won't idle. He says you have to stay on the gas a bit. What should I look at first? He thinks the carb sucked something up as it was rebuilt and sat for a bit. It has the flathead in it.
Respecting and Resurrecting Ford Model A's. |
#2 |
maybe a cracked vacuum hose, or a loose base on carb, or loose intake bolts.
Does it start easily, or does he have to prime it ? .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV. ![]() |
#3 |
#4 |
Could also be excessive wear on the carburetor butterfly shaft. I've had air leak in there and prevent idling.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
#5 |
Remove the 2 idle air screws, take the air hose and blow into those holes, sometimes a piece of crap will get in the idle system, It won't hurt anything. Walt
#6 |
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
#7 |
Any crap in the fuel tank?
1939 Fordor Deluxe 1939 Ford Coupe Std 1940 Ford pickup Nothing in life is to be feared; it is only to be understood. |
#8 |
Pull carb and thoroughly clean it. Drain some gas and smell it--- that distinctive varnish smell is a dead giveaway.
#9 |
Could also be a bad power valve.
'52 F-1, EAB flathead |
#10 |
He told me he does have to prime it if it sits at all. He said it runs like a top but dies if you let your foot off the throttle. He did say the tank was empty. Engine was rebuilt and then the truck sat.
#11 |
#12 |
I am, with Walt try the easy stuff first ,if no go !pull as much of it to bits s possible and blast it out with at least 100 PSI .Ted
#13 |
It could be as simple as the throttle linkage is bent on firewall,
not closing plate all the way. Worst is you have a thumper cam. |
#14 |
Sounds like a leaking powervalve to me as well; I have run across several mis-fitting power valves in my travails.
#15 |
He said it used to idle very nicely and this just started happening. I will take a look at the carb and throttle linkage.
#16 |
Looking at the linkage is fine. BUT, the tell in your comments is the need to prime for starting. Something is causing the bowl to drain - most typically, the power valve is the issue. Best bet is to remove the carb to clean it and check the valve seal.
#17 |
I know on a Stromberg the power valve is below the out lets so drain down doesn't exist ,to slow carb evaporation ,pull the choke out to seal off the top after shutting down .
#18 |
No choke is hooked up at the moment. Would a bad powervalve not allow it to idle? I have had cars leak down before but after it starts and the fuel pump starts working it runs fine.
#19 |
In your first post you said you "have a 48 ford truck on it's way". Has it arrived or are we doing third person troubleshooting? That would be kind of theoretical troubleshooting.
Lonnie |
#20 |
