Old 01-05-2015, 09:02 AM   #1
Jerry Kzoo
Jerry Kzoo's Avatar
Default 29 gas tank attachment
I picked up a 29 cowl and was wondering about the gas tank attachment to it. It says to use 1/4-20 bolts to attach the front and back flanges and clamps for the sides. I am wondering why the use of clamps when there seems to be 5 matching holes on both pieces on each side. I am not familiar with the clamps, but do they locate and nest in these holes? This cowl did not come with these clamps, but it is from a Coupe or Tudor I think.
Thanks, Jerry
Jerry Kzoo is offline   Reply With Quote
Old 01-05-2015, 09:26 AM   #2
newshirt
newshirt's Avatar
Default Re: 29 gas tank attachment
Are you referring to these ten clamps? (5 on each side)
I wondered the same thing, and assumed the answer was that the pinchers at the end of the clamps ensured that the cowl meets the side perfectly without separating. In other words, when you tighten the bolts, the clamps pinch the metal at the very edge tightly so no gap can form.
Ray White
newshirt is offline   Reply With Quote
Old 01-05-2015, 09:48 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes, Ray has it correct. The clamps actually transfer the pressure causing it to tighten at the edge.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-05-2015, 10:29 AM   #4
Jerry Kzoo
Jerry Kzoo's Avatar
Thanks for the quick reply with pictures!! Makes sense now. You guys on the Barn are the best!!
Jerry
