12-26-2014, 10:00 AM | #1 |
Combination Instrument light and switch
A Newbie Question:
Happen to see this Combination Instrument light and switch and where might is be located --if my car has one the light might be burned out?
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
12-26-2014, 10:10 AM | #2 |
Re: Combination Instrument light and switch
On the round speedo cars you will find it just under the dash rail above the panel. Run your hand under there or look with a mirror. There is also a little mouse-hole notch near the top of the panel for the single steel-wound (armored) connecting wire to the ammeter. There is a little lever to turn it on/off. Don't forget, or you will have a dead battery if parked for days with it on. The oval speedo cars have the light assembly in the panel itself.
12-26-2014, 10:15 AM | #3 |
Push and twist the instument light housing & your inst light should come on if bulb is good. For the oval speedo.
Steve Hanna, Polk City, IA |
12-26-2014, 12:15 PM | #4 | |
12-26-2014, 12:27 PM | #5 |
The light is above the gas gauge , behind the dash rail. Not part of the dash panel that you show in picture. That's if have the round speedo.
12-26-2014, 01:58 PM | #6 |
http://www.ebay.com/itm/Model-A-Ford...c9e526&vxp=mtr |
12-26-2014, 02:39 PM | #7 |
Well appears no such switch...
12-26-2014, 02:45 PM | #8 |
The switch is on the light.
Bob |
12-26-2014, 03:00 PM | #9 |
They're reproduced. Most vendors have then.
Paul in CT |
12-26-2014, 03:22 PM | #10 |
12-26-2014, 04:55 PM | #11 |
I wired mine to come on with the tail lights. The switch is still there in case I want to turn it off.
12-26-2014, 05:01 PM | #12 |
That Bad Boy gets HOT if left on too long... I think I left my fingerprints on the chrome cover, permanently, when I went to shut it off!! I have since replaced the bulb with a LED.
12-26-2014, 05:03 PM | #13 |
you got that right, its like sticking your finger in a hot cig lighter element
12-26-2014, 05:12 PM | #14 |
12-26-2014, 05:24 PM | #15 |
See the wiring diagram on page 94 of the Brattons catalog and you will see the instrument light and how the wire connects to the ammeter on the mid 30 thru 31 cars with the round speedometer. Brattons catalog is about the best referance that a model A owner can have .
12-26-2014, 06:32 PM | #16 | ||
R /Roger. |
12-26-2014, 07:34 PM | #17 |
12-26-2014, 08:40 PM | #18 |
Don't know. I was going to look for an LED lamp that would fit.
12-26-2014, 09:58 PM | #19 |
How does the switch turn on?
12-26-2014, 11:16 PM | #20 |
Oval speedometer, turn cap to turn on , round speedo, flip switch on lamp housing under dash rail.
