12-24-2014, 02:10 PM | #1 |
Need help with horn button restoration
I,m looking for tips on removing old paint from my horn button, and general restoration advice.
Thanks in advance. |
12-24-2014, 02:29 PM | #2 |
Re: Need help with horn button restoration
NG
The only way to really do a thorough job is to take the thing apart. With the switch rod removed from the shaft, below the total switch knob are 4 tabs that must be carefully straightened to remove the chrome ring that secures the horn button. After removing the ring, the button will come out (there is a spring underneath). Then you can refurbish as necessary. Again, be VERY careful when straightening the tabs, cuz they gotta go back Merry Christmas Jim |
12-24-2014, 02:30 PM | #3 |
If that horn button is made of plastic I would consider using very fine wet/dry emory paper and soapy water. It will take some patience and time. Or, perhaps Q-tip and a solvent that doesn't dissolve plastic, like kerosene or gasolene. Try a spot on the backside first as a trial run.
12-24-2014, 03:49 PM | #4 |
NG Be very careful with those tabs because it looks like the button has been removed once before and rotated 90 degrees. See image for proper orientation of V-8 on switch.
12-24-2014, 09:53 PM | #5 |
Thanks guys
I can get it apart, what I'm really concerned with is removing the old paint and polishing the button to a like new shine with out damaging the part. |
12-25-2014, 01:56 PM | #6 |
12-26-2014, 11:40 PM | #7 |
I used low odor paint thinner and a Q-tip. Worked slow and not much pressure. I assume these are soy based plastic like the rest of the early Ford plastic. It took a while but all the paint came off.
12-27-2014, 04:09 AM | #8 |
Paint stripper then 2K
