Old 12-17-2014, 08:04 AM   #1
bart40
bart40's Avatar
Default Removing door handles from a 40
I need to remove the outside door handles and key holes from my 40. (It's a 4 door so I've got a few) I've done some staring at it but haven't figured it out. Any thoughts? Thanks.
bart40 is offline   Reply With Quote
Old 12-17-2014, 09:07 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Removing door handles from a 40
turn them like opening the door, wiggle and pull--after the screws are out
there is a set screw in from the side for the lock cylinder
Old 12-17-2014, 09:35 AM   #3
Kube
Kube's Avatar
You do not need to remove the lock to remove a handle. You do need to remove the screw (it's in the door jamb) though. Then, simply pull it out.
The lock cylinders can be a test in patience if the set screw is rusted in. the screw is a #8 if I recall correctly. Being that small and threaded deeply in to a sheet metal "sheath", well, if it is rusted, think "lots of patience". I typically will remove the door panel and heat the threaded "sheath" and slowly twist the set screw back and forth to remove it.
Authentic set screws had a slotted head which makes this task even more of a challenge.
Old 12-17-2014, 10:23 AM   #4
TJ
TJ's Avatar
If you are not interested in authenticity replace the set screws with an allen head set screw.
Old 12-17-2014, 06:12 PM   #5
bart40
bart40's Avatar
Thanks all! It worked.
