Old 12-15-2014, 11:03 PM   #1
Farmer j
Default Fender welding
I'm working on a 1931 68C Model A. Does fender welting go between the front fender and the splash pan? How about between the rear fender and the splash pan? Does it go between the splash pan and the running board or between the running board and front and rear fender. I can't find any pictures that show this and need any help I can get.
Farmer j is offline   Reply With Quote
Old 12-16-2014, 01:48 AM   #2
mot
Registered User
mot's Avatar
Default Re: Fender welding
the front welting goes between the fender and the splash shield
the picture shows a 30 car,which has a different splash shiled
but you can see where the welting goes between the shield and fender
the back is a little more complicated,under the body above the shield ,its tucked in and then where it meets the running board it just dives down
it does not go between the running board and fender either front or rear
this is an original car
tom
mot is offline   Reply With Quote
Old 12-16-2014, 02:03 AM   #3
larrys40
Welting photos from MOT are great reference.... I also have one to restore... can you post some photos when you can... Would love to see them!
Larry S.
larrys40 is offline   Reply With Quote
Old 12-16-2014, 08:41 AM   #4
Farmer j
A big thank you to MOT. Larry, would you be interested in a new Cartouche interior for a 68C? It is the brown Bedford cloth, still in the box.
Old 12-16-2014, 09:55 AM   #5
LopezCarguy
LopezCarguy's Avatar
Welting goes between fender and spash apron both front and back on Cabby's
The only thing worth learning is what you learn after you know it all !!
LopezCarguy is offline   Reply With Quote
