Old 12-13-2014, 03:52 PM   #1
boatbob2
Default Wheel adapter for model A
Needed: wheel adapter for model A,to go from 5X 5 1/2 inch to5X 4 1/2 inch 5 bolt wheels
boatbob2 is offline   Reply With Quote
Old 12-13-2014, 04:16 PM   #2
Charlie Stephens
Default Re: Wheel adapter for model A
When you find your wheel adapter be sure it allows for the fact that the stock Model A hub and drum is at two levels or you might end up watching you tire go down the street in front of you. Here is a post on a slightly different topic but it shows what I am talking about: http://www.jalopyjournal.com/forum/t.../#post-8330045 PS, I like the stock wire wheels or Kelsey's.
Charlie Stephens
Old 12-13-2014, 04:31 PM   #3
denis4x4
denis4x4's Avatar
I suspect that you're going to have to have that combination custom made. I had I had a pair of adapters made to use 5 on 5-1/2 Kelsey wire wheels on trailer axle spindles with a 4 bolt pattern 10 years ago and it cost me $140 for the pair.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
