Old 12-03-2014, 10:03 AM   #1
Ray64
Ray64's Avatar
Default Fuel leak
Can someone tell me the angle on the fuel line so I can buy a dremel stone to finish the carb inlet. Looks pitted so I want to just dress it up a smidge? Thanks RAY
Ray64 is offline   Reply With Quote
Old 12-03-2014, 09:03 PM   #2
rocket1
Default Re: Fuel leak
not sure of the angle but the brass fitting on the fuel line usually will dig into the taper in the carb and not leak,be careful not to overtighten and crack the casting
rocket1 is offline   Reply With Quote
Old 12-03-2014, 10:28 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
You could take a piece of tubing with a ferrule on it and use some valve grinding compound to smooth out the seat
Another method I have used is to coat the ferrule on the fuel line with solder, the solder being soft will conform to the irregularities of the carb
doing both will most likely cure your problem
Old 12-03-2014, 11:44 PM   #4
Brian T
Brian T's Avatar
Hello Ray.
Here is a link to where the dremel stone to refinish the fuel inlet pipe seat is mentioned, go down to Tom Endys entry.
https://www.fordbarn.com/forum/showth...=zenith+dremel
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 12-04-2014, 02:25 AM   #5
Tom Endy
Tom Endy's Avatar
Dremel part number 911 is what you need. I could not find them in a store, but was able to purchase on line.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 12-04-2014, 04:21 AM   #6
johnbuckley
johnbuckley's Avatar
45 degree according to Gordon Biggar 's "Restoring Carbs the Rex Reheis way". ( pages A-7 and A-8, figure A-14) but it's not that critical- look at the brass olive it's going to take and go by that.
johnbuckley is offline   Reply With Quote
Old 12-04-2014, 08:47 AM   #7
Ray64
Ray64's Avatar
Thanks Fellows. Will try to get one today. By the way the carb Is a ZENITH RAY
