Old 11-30-2014, 05:04 PM   #1
Macdozer
Default Cleaning engine bay
Sense I have the engine out to the car I figured now is a good time to clean everything and maybe paint a few things.
Here is how it looks now
I am thinking the best way to do it is some degreaser warm water and elbow grease. Maybe a wire brush on a electric drill.
Just wondering if anyone has any advice
What kind of paint should I use on frame and cross members?
Macdozer is offline   Reply With Quote
Old 11-30-2014, 05:14 PM   #2
flatford8
flatford8's Avatar
Default Re: Cleaning engine bay
If that is the original I would leave it alone...... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 11-30-2014, 05:20 PM   #3
19Fordy
19Fordy's Avatar
Degreaser, scraper, wire wheel, safety goggles plus the elbow grease you add.
It's one of those tasks where once you start the more you need to do to make it nice.
It's worth doing in my opinion.
Old 11-30-2014, 05:53 PM   #4
TJ
TJ's Avatar
Put a plastic bag over the front of the torque tube. You don't need water/degreaser in there. Put the degreaser on and let it sit over night. You might think about using a power washer and set it at the lowest pressure possible.
Old 11-30-2014, 05:58 PM   #5
Ross F-1
Ross F-1's Avatar
I find that a kerosene-based cleaner (Gunk) is best for the first round; soak, let sit, then scrape with a plastic scraper. Once you get down to thin layers of oily mess, then the Purple Cleaner type stuff with a good hot water rinse finishes it up nicely. The really mild Scotchbrite (usually blue colored) is great stuff, as are a good pair of thick nitrile gloves. It will make a mess for sure!
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 11-30-2014, 06:01 PM   #6
CC33
CC33's Avatar
I have had very good results with Simple Green degreaser.
CC33 is offline   Reply With Quote
Old 11-30-2014, 06:13 PM   #7
bobH
Be careful with the auto-store engine degreasers. I used one once that ate paint. 'Overnite' would be out, for me. Wish I could remember which brand.
bobH is offline   Reply With Quote
Old 11-30-2014, 06:41 PM   #8
waterboychuck
waterboychuck's Avatar
Don't clean it too much as it will turn into a trailer queen.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 11-30-2014, 07:35 PM   #9
chap52
chap52's Avatar
I've had good results using "Purple Power" and it's a "green product".
chap52 is offline   Reply With Quote
Old 11-30-2014, 08:32 PM   #10
charles in east texas
charles in east texas's Avatar
Awesome. $1 a bottle at $ a General. Charles
charles in east texas is offline   Reply With Quote
Old 12-01-2014, 05:36 PM   #11
Macdozer
Thinking of just cleaning it up and maybe using some fluid film on it to help protect it. Has any one used fluid film on your cars before?
Old 12-01-2014, 06:51 PM   #12
supereal
supereal's Avatar
We use Super Clean as a solvent. It is safe, but use eye and hand protection. It may take several applications, but it will rinse off old dirt and grease with water.
supereal is offline   Reply With Quote
Old 12-01-2014, 07:06 PM   #13
russcc
I prefer WD-40, it cleans off the dirt & grease with a tooth brush or rag, does not affect the paint, and leaves a temporary rust resistant coating on the area you just cleaned.
russcc is offline   Reply With Quote
Old 12-01-2014, 08:37 PM   #14
RalphG
RalphG's Avatar
Diesel fuel and rags works well on the open stretches but some tighter places will require long hours with an old toothbrush and elbow grease.
RalphG is offline   Reply With Quote
Old 12-01-2014, 09:54 PM   #15
Mike B
Rent a steam cleaner if you don't have one, simple, fast and no chemicals, no wait time.
Mike B is offline   Reply With Quote
Old 12-02-2014, 06:06 PM   #16
El Rat
Maybe cover the torque tube and haul your little dumplin to the car wash. That way you can do it fairly quickly and no driveway to clean afterwards. Also note the Super Clean (Purple bottle) is a great cleaner but if left on too long it will eat paint and more!!!
El Rat is offline   Reply With Quote
Old 12-03-2014, 08:56 AM   #17
Mike51Merc
Mike51Merc's Avatar
I do a dry scraping first with a dull putty knife, screwdrivers, picks, etc.. This removes the large chunks and loose stuff that you can vacuum up with a shop vac instead of creating a wet greasy muddy mess first.
Second stage is a petroleum based degreaser (like kerosene. diesel, WD40, mineral spirits or the like) to act as a solvent to loosen and remove the greasy stuff.
Third stage is a thin non-petroleum solvent (denatured alcohol, detergent/water solutions) to remove the second stage.
If it's still oily then I'll spray and wipe with brake cleaner as a preparation for paint.
Mike51Merc is offline   Reply With Quote
Old 12-03-2014, 09:06 AM   #18
gmc1941
gmc1941's Avatar
One problem..... Where do you start and where do you finish.
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
Old 12-03-2014, 09:51 AM   #19
cmbrucew
cmbrucew's Avatar
Starting is your option, and 3 or 4 finishes are about right.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 12-03-2014, 12:36 PM   #20
wspiker
wspiker's Avatar
Use a wire disk on a grinder.
wspiker is offline   Reply With Quote
