Old 11-22-2014, 11:54 AM   #1
Brendan
Brendan's Avatar
Default wiper blade
where can I get a wiper blade like this? and what year is it for? thanks Brendan
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 11-23-2014, 05:32 AM   #2
Tom Morookian
Tom Morookian's Avatar
Default Re: wiper blade
resize the photo. Can't tell anything like it is
Tom Morookian is offline   Reply With Quote
Old 11-23-2014, 06:22 AM   #3
koates
Brendan, That wiper blade is from 1970s period. Trico was one company that made them. Not correct type for early Fords. Regards, Kevin.
koates is offline   Reply With Quote
Old 11-23-2014, 10:29 AM   #4
TJ
TJ's Avatar
Brenden, if the blade uses an insert type rubber blade you can get the inserts at your local Walmart. They will be too long, but you can cut them and get two inserts for the price of one. I've done that using the same arm you are using.
Old 11-23-2014, 10:53 AM   #5
Brendan
Brendan's Avatar
its very narrow, any idea what year the arm is from? its for my Model A, the A has a Bosh 12 volt motor on it . I have seen a wiper arm like it before but I don't know where
Old 11-23-2014, 11:28 AM   #6
Ross F-1
Ross F-1's Avatar
Looks like the old British type, used on MGB's etc. Those are also the size used on 48-52 F-series. I bought replacement Trico blades at O'Reilly's, p/n TRI 33-101
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 11-23-2014, 12:30 PM   #7
Brendan
Brendan's Avatar
Thanks , I thought it was a early 50s ford
Old 11-23-2014, 01:17 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
Believe you are correct. This is the original wiper arm and replacement blade ( made to use two different arm configurations) on my '51 Merc.
12 inch replacement blade is Trico 33-122
