Old 11-18-2014, 06:59 PM   #1
d.
Default freeze plugs ?
Why did Henry not have freeze plugs in the Model A block? He had them in the Model T, but then chose not to include them in the Model A.
How come?
d. is offline   Reply With Quote
Old 11-18-2014, 07:45 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: freeze plugs ?
USUALLY freeze plugs in an engine especially modern engines is its a hole used during the casting process and then yes doubles as a freeze plug hole so your block doesnt (supposedly) crack.
Maybe he had a different casting method for A engines?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 11-18-2014, 08:02 PM   #3
Joe K
Joe K's Avatar
Henry was quite proud of his "cast en-block" one piece engine blocks. Perhaps he viewed a requirement for additional holes as some sort of compromise to his ability to cast a block?
My experience with frozen Model As is the damage is usually done to the head by pushing up a section adjacent to the distributor. Not to say that it can't or won't cause damage elsewhere.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 11-18-2014, 08:03 PM   #4
redmodelt
redmodelt's Avatar
That is correct they are core holes that get a welch plug to seal in the Model T and many other motors. Even with them the T likes to crack on the drivers side anyway!
