Old 10-25-2014, 04:15 PM   #1
jack99
Default Correct gear oil for 1935 Ford
What is the correct weight gear oil for a 1935 Ford V8 transmission? Should I use the same "600W" that I use in my model A or something different? Thanks for your input.
jack99 is offline   Reply With Quote
Old 10-25-2014, 04:19 PM   #2
JSeery
JSeery's Avatar
Default Re: Correct gear oil for 1935 Ford
Believe 600W is a type of oil, not an oil weight.
Old 10-25-2014, 04:49 PM   #3
CT AV8
CT AV8's Avatar
Jack, I have a '35 transmission in my AV8 and I use the same 600W from Bratton's that I did with the Model A transmission. I'm happy with it.
CT AV8 is offline   Reply With Quote
Old 10-26-2014, 07:53 AM   #4
Planojc
Planojc's Avatar
That's what I use in my 35 and my Model A's.
Planojc is offline   Reply With Quote
Old 10-26-2014, 08:50 AM   #5
JSeery
JSeery's Avatar
http://www.bobistheoilguy.com/viscosity-charts/
600W is an ISO rating I believe which would be about 140W SAE. 600W gear oil is not 600 wt oil in the commonly used ratings of today, it is the equivalent to 140 wt gear oil. Attached is a scan from a Brattons catalog (from an earlier Barn post).
Old 10-26-2014, 09:56 AM   #6
rotorwrench
rotorwrench's Avatar
600 steam cylinder oil predates the SAE ratings. It dates back to the 19th century. The owners manuals for the early Ford V8 cars should have SAE rated lubricants like straight grade GL-1 oils. 600W was listed for Model A car steering boxes but I don't think FoMoCo recommended it in the V8 era. SAE 80, 90, and 140 have all been used for lubricants plus the soda soap oil for U-joints.
Steering gears can use anything you can pour in there as long as the seal is good. Folks always go back to the 600W/600 or STP when they have a leak they don't care to repair.
Old 10-26-2014, 01:32 PM   #7
supereal
supereal's Avatar
The "600 weight" oil is basically a thin asphalt solution that was devised to try to contain leakage in Model T and A vehicles that had little or no effective sealing. It should NOT be used in later transmissions or rear ends. If your transmission is not badly worn, the 80-90 weight gear oil is recommended. A leaky gear box or rear end would benefit from using 140 weight gear oil, unless you drive in a cold climate. Both have "high pressure" additives, and are light years ahead of the archaic "oils" such as 600W.
supereal is offline   Reply With Quote
