10-09-2014, 07:55 PM | #1 |
windsheild glass replacement
Whats the trick to getting out stuck screws to replace the glass in a 29 coup. I've soaked them with WD40, Trans fluid and acetone, PB blaster, put heat to them, and they don't budge----any tricks?
Hotrods don't have valve covers |
10-09-2014, 08:03 PM | #2 |
Re: windsheild glass replacement
That can be a very tedious job! but keep 'em soaking. I went through that years ago. Without a fine point acetylene torch flame to really heat up the screws, it was a small, cold rolled chisel & hammer, tapping counterclockwise on each head. They finally budged, I remember using vise grips too. I think 2 broke off & had to drill & re tap but not a hard job there. Time with soaking is the key, I think.
10-09-2014, 08:03 PM | #3 |
a good quality impact driver usually works for me. wear eye protection
10-09-2014, 09:01 PM | #4 |
This is a chore I have ahead of me, and I am therefore interested in any tips and experiences that will help. So thanks!
10-10-2014, 12:51 PM | #5 |
it is pretty easy to damage the head of a small slot screw such that drilling it out is easiest. Then drill it out with a bit smaller than the thread diameter and use an easy out, run a tap through it, then replace the screw.
10-10-2014, 01:10 PM | #6 |
10-10-2014, 03:28 PM | #7 |
Valve grinding compound on driver tip gives some bite, lay wind shield
down flat, use a driver with hex shank, push down hard, small wrench on hex, and turn carefully! Someone posted about using engraving pencil maybe vibrate on screw? Have not tried that trick. Good luck keep us posted |
10-10-2014, 04:34 PM | #8 |
If the glass is removed, heat will almost always work. Heat the head cherry red, but don't melt the head. Sometimes quenching the hot screw will help break the rust seal. If you try to unscrew the small screws while hot, they usually come out. Once the heads cool down, the screws can also usually be removed. Sometimes on real stuck screws, it takes 2 or 3 heat cycles to break the screws loose. This is the way I removed the screws from my 28 special coupes windshield. Good luck.
Rusty Nelson |
10-10-2014, 04:37 PM | #9 |
I've been told that iodine works good for loosening seized bolts and screws but never tried it myself.
10-10-2014, 05:55 PM | #10 |
IODINE? sounds like a setup post for bill w
10-10-2014, 08:24 PM | #11 |
Heat, heat, heat. You will have them out in 5 minutes
10-14-2014, 10:09 AM | #12 |
Update-----I used heat and a Harbor Freight impact driver and they popped out easily
10-14-2014, 07:02 PM | #13 |
Who says Harbor Freight doesn't work ( lol ) ?
Wayne |
10-14-2014, 08:30 PM | #14 |
heat and kroil...lots and lots of it...put it on walk away and let it soak. I still have to shock link arms soaking from a month ago.
IODINE? now that is funny.... |
