Old 10-06-2014, 07:18 AM   #1
47Merc
Default 40 Deluxe windscreen garnish mould
Hi
My 40 Deluxe has a 1/8 inch white fender welt type plastic moulding between the dash and the windscreen garnish moulding that is pretty crappy and I would like to replace it.
Anyone know what this moulding is called and where to buy it?
Thanks
47Merc is offline   Reply With Quote
Old 10-06-2014, 07:56 AM   #2
BABAR40
BABAR40's Avatar
Default Re: 40 Deluxe windscreen garnish mould
I think Macs has them, about 50 inches long.
BABAR40 is offline   Reply With Quote
Old 10-06-2014, 08:35 AM   #3
4dFord/SC
4dFord/SC's Avatar
It's called welting, and Roy Nacewicz has it: http://www.fordscript.com/ford_bolts/products.html. It comes in black, and is to be painted the same color as the dash, i.e., Mandarin Maroon for '40 Deluxe, if memory serves (help me out here, Kube).
4dFord/SC is offline   Reply With Quote
Old 10-06-2014, 08:41 AM   #4
TomO
The correct welting is available from Roy Nacewicz.
BUt seeing that you are from down under, you might be able to source it locally. It is the same as the fender welting and is 49 3/4" long. It should be painted the same maroon as the dash.
TomO
TomO is offline   Reply With Quote
Old 10-06-2014, 10:50 AM   #5
19Fordy
19Fordy's Avatar
The welting looks like this. An upholstery shop could make you a piece. I bought the dash colored piece from LeBaron Bonney years ago.
