#1 |
Recently, a friend purchased a 1935 ford. Tried to refuel and was troublesome. Gasoline kept backing up no matter how slow you refuled. Was the tank origionaly vented? I can not find any vent to evacuate the air. Any info would be helpful. Thanks in advance for your reply.
#2 |
my brothers 35 ,5 window is the same way .You have to fill it really slow , or it burps back at you
#3 |
The '35 gas tank has a vent tube on top of the hydrostatic sending unit that's mounted on top of the tank. There is an access door in the rear section of the floorpan directly over the gas tank.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 10-01-2014 at 09:19 PM. |
#4 |
Park it so the left side is high when filling. It helps.
I don't have the hydrostatic sending unit on mine and I have not seen a vent tube on the top of my tank. My sending unit is with a float and resistance; aftermarket and doesn't work that well but that is for another time. |
#5 |
On my 35 rd I stick a piece of 3/8 clear plastic hose about 2 ft long in the tank with the curl pointing up into top of tank , works pretty good still go slow
DON P |
#6 |
#7 |
This a common problem especially with '35s. To get around this
I came up with two easy solutions. Note the pictures. The simplest type is simply welding a 1/4" o.d. tube (brake line tube is o.k.), inside the existing neck and intruding beyond the neck itself. This will prevent about 90% of any back-ups. The second type is a little more complicated but prevents 100% of back-ups and you can fill the tank as fast as possible. You will need to drill an extra hole in the tank near the fuel sender outlet. I used a 3/8" bit . I then used a brass 90 degree elbow with a short 1/2" piece of copper tubing on one end. It is a good idea to make a small piece of gasket material for a seal or use a good liquid sealer. Insert the threaded part of the elbow into the hole and attach the brass female cap (with copper tube attach) on the inside of the tank. I know this sounds difficult but if the drilled hole is close to the fuel sender hole you can get the cap on with a minimum of difficulty. Tighten the cap/elbow. On the top side of the tank connect another 1/4" copper or steel tubing (about two inches long) to the brass elbow. I added a brass bushing to the tube on the end to make for a tight hose fit. You are now finished with the tank. Next drill a 1/4" hole in the fuel neck just below the fuel tank opening cap. Add a 6-8 inch piece of 1/4" steel tubing. Insert one end of the tubing in the previously drilled hole. Weld this tube at the top and bottom. I also added a 1/4" bushing to the end of the tube. Finally, just connect the two tubes with a piece of fuel resistant hose with some clamps and you are done! Oh yes, one more thing. To get the neck off the tank (these things can be troublesome), you will need a spanner wrench (note picture) and a couple of days of an oil penetrative such as Kroil. Putting it back you will need a new lead seal ring. Hope this helps. Tom |
#8 |
Try turning the nozzle 180 degrees. G.M.
www.fordcollector.com |
#9 |
My 35 tudor will take fuel as fast as delivered. Everything is original so there must be something plugged up on your vent system. If you clean the vent tube accessible through the inspection plate in the trunk It should work.
#10 |
Mine will burp back also. I put the nozzle in half way and keep an eye on the flow.
#11 |
Hi Everyone, Jack99, it sounds like your buddy has a clogged vent, but since you asked for any info here it comes...
I agree with GM. Here's what I try with my '36. Snapped this morning while prepping for the AACA meet. I go about half way OR LESS on the flow, not full bore like is the routine on my modern cars. I also don't typically fill more than 3/4 full because I've seen six or eight cars that have been filled to full, only to have the fuel expand and overflow while the car is parked in the sun which does ugly things to the paint. When you look at the next '35-36 look around the filler and tail light. Few (non-trailer-queen) vehicles are pristine in that area! I even saw a '36 in the car corral this year, parked on a slight right-to-left angle, that puked fuel and ruined the paint, I think a Folkstone Grey car. They had a bumper jack nearby where they had tried to scramble to raise the driver's rear corner to avoid more damage. Saw a maroon Phaeton two years ago in the Green field on level ground with a FOR SALE sign on it, just sitting there with a puddle under it, paint looking like a fried egg. I even tried to call the owner just to be a nice guy. Let's not talk about the fire hazard. BTW, who sells a car with a full tank of fuel???? Seen it on '36's two of the last three years I've attended Hershey. I usually fill by the gallons. Often just seven gallons. I don't ever rely on the pump to sense the vapors and cut off. Of course that won't work because of the way I hold the nozzle out of the filler. If I know I'm going on a long drive I'll do more. But you still have to watch out for hard right turns (often as you leave the fueling station) which will puke it out onto the fender too!
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 10-10-2014 at 08:19 PM. |
#12 |
I have always used Ditzler enamel paint with proper amount of hardner in it and never had any problem with spilled fuel discoloring it. I am not a fan of the "color coat-clear coat" paint which is not as tough as enamel with hardner.
