#1 |
Morning
I installed a Zenith carb on my model a . When I start it, I can hear air rushing into the carb. (whisle noise) It did not make that noise with Tillotson. Thanks Tom |
#2 |
Sounds like you have an air leak, either the gasket on the manifold or where one of the butterflies are.
#3 |
You have a leak in the system. Check you vacuum line connections if you have one...
#4 |
Not much info. New, used, rebuilt ? New manifold to flange gasket ? All the pieces where they should be ?
#5 |
Missing Venturi will make noises .... and still run sort of ...
#6 |
Tom Endy |
#7 |
Thanks All
Tom |
