#1 |
Anyone know if you can buy 1940 ford pickup rear steel fenders? I need 2 for my truck. Thanks everyone.
'40Garage |
#2 |
Nope - they are not repopped. Check with HamtownAl here - he has some steel rear fenders .... 38-39-40-41 are the same ....
#3 |
Keep an eye on "The Swap Meet" as seen at the top bar of the page here. Sometimes there are better deals if you're willing to travel. A few people have resorted to buying several cheap damaged fenders and splicing as many as six different fender sections together to make one good one.
Lonnie |
#4 |
Repop rear pickup fenders would be an item that Drake or Carpenter should make. They would sell a bunch of them. The same fender was used from 38-41
#5 |
TJ, I agree with you 100 percent. They should get started at once.
'40Garage |
#6 |
I have a left rear and will have it at Hershey at space C4K40. It is a take-off when I did my '40. Email me if you need info. Milt K from Pa |
#7 |
It is strange you can find tons of front fenders for those years but rears are a different story. Maybe they we're beat up more often due to being a truck or something.
Drake just started making 36 coupe rears so you never know. |
#8 |
I think a while back Dick Spadaro had some NOS fenders, you may want to give Bill a call and see.
#9 |
At the last big swap meet in town I saw one for $250. Problem was that it was beyond fixing. Go figure.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
#10 |
If you can weld. You can make 42 to 47 ford pickup rear fenders work.
#11 |
Could anyone tell me what you have to do to make a 42-47 fender work on a 40/41?
Thanks. Mart. |
#12 |
Fenders mount differently at the running board area,( I think there are repair panels that you can buy to make this work), and you would need to add "hole" for the gas filler.
#13 |
The 42/47 also doesnt have the dimple for the spare tire that the right 38/41 has. The shape were it meets the running board is different along with the bolt patter. Patch panel or junk donor is what you need to change it
#14 |
