Old 09-09-2014, 09:50 AM   #1
jim t utah
Default temp and oil pressure gauges
any recommendations on gauges for temp and oil pressure . thanx jim t
jim t utah is offline   Reply With Quote
Old 09-09-2014, 11:27 AM   #2
oliverguy
Default Re: temp and oil pressure gauges
I would use a motor meter or a thermo quail. The gauges available require you routing the cap tube all over the place to get it to the dash. In my opinion it's not needed when I can loook through the windshield to see the temp. I would use the dip stick for oil indication. The model a is not a fully pressurized system so an oil pressure gauge is not needed.
oliverguy is offline   Reply With Quote
Old 09-09-2014, 11:31 AM   #3
jkeesey
jkeesey's Avatar
I have one of the temp gauges sold from the major dealers and it works nicely. Im pretty sure theres not much difference between it and the Sunpros you can pick up everywhere besides a pretty needle and faceplate. I also bought on of the water inlets with the gauge bung cast in so installation is easy an clean looking. Im running an original 26 chevy gauge for the oil. It reads up to 10psi and works like a charm. I prefer to know exactly what my engine is doing and the gauges are the way to go for that.
jkeesey is offline   Reply With Quote
Old 09-09-2014, 11:51 AM   #4
Charlie Stephens
I think Bratton's sells a reproduction of the REX-A-CO gauges. Either that or look for a used set. Remember you need a 0-10 pound gauge for the oil. Bratton's has mounts for the steering column or below the stock dash. On the other hand, when the radiator gets too hot it sends out steam and when the oil pressure goes to zero the engine knocks soon stops. FYI, I don't run gauges on mine but after I finish everything else I may add a set.
Charlie Stephens
Old 09-09-2014, 05:37 PM   #5
Don
Don's Avatar
Tried two Sunpro temp gauges,both were off about 15 deg,got money back ,looking for something a little better,
DON P
Don is offline   Reply With Quote
Old 09-09-2014, 08:48 PM   #6
tbirdtbird
I'm running an electrical temp gauge not the mechanical one with ether in the bulb. Way easier to route
'31 180A
tbirdtbird is offline   Reply With Quote
