Old 08-20-2014, 06:52 PM   #1
holdover
Default Quality of this item
Does anyone have any experience with the quality and fit of this item? With all the negative comments about the fit of repro sheet metal I want to check before I purchase something. thanks for the replies.
http://www.ebay.com/itm/370475656078...84.m1436.l2649
holdover is offline   Reply With Quote
Old 08-20-2014, 08:19 PM   #2
Gary Karr
Gary Karr's Avatar
Default Re: Quality of this item
This running board shield does not look like it will give you the fit or original look of originals. If you are going to go with new ones, get them from Rootlieb.
Gary Karr is offline   Reply With Quote
Old 08-20-2014, 08:40 PM   #3
daveymc29
daveymc29's Avatar
To my untrained eye, the bump doesn't look right, comparing to my 29 Roadster. I bought asset from someone, can't remember where, but my son in law, who is a body man, tossed them and made a pair from scratch that do look correct. Used my originals for something to work from.
daveymc29 is offline   Reply With Quote
Old 08-21-2014, 06:49 AM   #4
ericr
ericr's Avatar
from my view, it does not have the original offset flange on the end where it attaches to the rear fender....buy the ones that do, or else good luck trying to get it on.
ericr is offline   Reply With Quote
Old 08-21-2014, 07:14 AM   #5
wrndln
The splash aprons also don't have the small indentation along the front lower part where it bolts to the front fender. The splash apron looks a lot like the crappy Howell's junk - poorly made. It also appears that most of the slotted bolt holes are not punched. If you want a splash apron for a driver and don't care about authenticity, it will probably work, but not fit quite right. There are numerous original splash aprons available - why not buy a pair of them - they would be cheaper, but may require a little bodywork. That is what I do. Normally they are in decent condition. I almost always use original parts and have never had a problem with them fitting and looking correct.
Rusty Nelson
Old 08-21-2014, 07:23 AM   #6
C26Pinelake
Get it from Brattons and you will be happy ! I did and they fit perfectly.
Wayne
C26Pinelake is offline   Reply With Quote
Old 08-21-2014, 11:04 AM   #7
ericr
ericr's Avatar
I don't know how most people feel, but I would be unwilling to buy repro parts from hot-rod parts dealers. I really don't know what application their parts are exactly intended for and what standards those applications have. I would only buy from a tried and true Model "A" parts dealer like Bratton's, Snyder's or Berts,
Old 08-21-2014, 11:15 AM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
This seller is a dealer for Antique Auto Sheetmetal, ....a/k/a Brookville Roadster. AAS also sells to many of the Model-A part dealers.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-21-2014, 03:34 PM   #9
ericr
ericr's Avatar
-but how is one supposed to know who buys from whom and even if you were given one name, how are you supposed to know the company's aka's?
the ad ballyhooed the splash apron as something short of sliced bread, yet some of us do not regard it as the best one available.
Ergo, add in the mystery of the origin of the part, add in the advertising aspect....I'll still buy from a recognized Model A parts house.
Old 08-21-2014, 04:18 PM   #10
BRENT in 10-uh-C
Your point is well taken, ...and your last line is something we all should adhere to. Building a relationship with a parts vendor that knows the quality should mean more than placing an order with a mass-merchandiser whose attitude of low cost & poor customer service is the only thing they have going for them.
BRENT in 10-uh-C
Old 08-21-2014, 04:45 PM   #11
ericr
ericr's Avatar
well, you know, one thing I greatly appreciate about Bratton's catalog is that he is the only one I know that will state "the better of two made", "many dealers sell a type that....", etc. Maybe other parts houses state that, I have not seen all the catalogs.
