08-20-2014, 01:16 PM | #1 |
stovebolt
Why do they call Chebbys stovebolts? These are ALL of the headbolts for an old Chebby. They are 1/2" coarse threads 5 1/4" and 2" long.
If you are benefiting from Ford engineering pat yourself on the back. This is from an early 4-cyl head that they used on Model T's for racers. |
08-20-2014, 02:06 PM | #2 |
Re: stovebolt
Because they explode as you would expect an engine to do if assembled with stovebolts.
08-20-2014, 02:59 PM | #3 |
Re: stovebolt
If you look at an old potbelly coal stove or larger coal kitchen stove you will see that they are bolted together with large bolts similar to what was used in a chebby. Hence the name. Also, on a chebby engine they are much more prominent than on some other engines.
08-20-2014, 05:44 PM | #4 |
Re: stovebolt
Yep, what Joe said. LOL
Kevin
"Failure is simply the opportunity to begin again, this time more intelligently". Henry Ford. |
08-20-2014, 07:56 PM | #5 |
Re: stovebolt
I'm going to one of those heads on a Model B engine this winter. Walt
08-21-2014, 10:29 AM | #6 |
Re: stovebolt
08-21-2014, 02:07 PM | #7 |
Re: stovebolt
08-21-2014, 04:13 PM | #8 |
Re: stovebolt
The sides and valvecover on the old sixs were held on by 1/4" course thread screws commonly called stove bolts.
08-21-2014, 04:26 PM | #9 |
Re: stovebolt
We called them "babbitt pounders" too.
08-21-2014, 05:03 PM | #10 |
Re: stovebolt
Round head slotted bolts are still called "stove bolts". They were mostly used to hold the sheet metal cover on the right side of the engine.
