08-18-2014, 12:23 PM | #1 |
Fenton Headers in 40 car with Columbia
Anyone dealt with exhaust pipe and header clearance on the clutch pedal to valve disengagement linkage rod in 40 with 2 speed? Will Fentons work?
08-18-2014, 01:16 PM | #2 |
Re: Fenton Headers in 40 car with Columbia
i installed a Columbia in my `37 1/2 ton [same chassis as a `40] and used Fenton headers. i had to mill about .070" off the mounting face of the headers to clear the steering box and i had to modify the clamp-on clutch pedal bracket slightly. i think i had to offset the clamp-on clutch pedal bracket about 3/4" to clear the head pipe. i`ll post a few images later if you want.
tom |
08-18-2014, 03:20 PM | #3 |
I had no problems installing a Columbia two-speed axle in my '40 with Fenton headers.
08-18-2014, 04:34 PM | #4 |
here are the images.
tom |
08-18-2014, 09:43 PM | #5 |
