Old 08-16-2014, 11:56 PM   #1
wga
wga's Avatar
Default 8BA timing jumps a few degress
Noticed that my initial timing set on the 'bump' moves occasionally, a few degrees advance. The distributor is a Mallory dual points, with 600 miles use, so the distributor gear is not worn. Usually it stays right on the bump. Normal or??
thanks.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 08-17-2014, 06:33 AM   #2
JWL
Default Re: 8BA timing jumps a few degress
I would call it "normal" for an engine with clearance between the cam thrust faces and the block/front cover. For a full explanation you can read my book but the general epitome is the spiral gears change the timing as forward and rearward movement occurs.
JWL is offline   Reply With Quote
Old 08-17-2014, 05:47 PM   #3
supereal
supereal's Avatar
I agree. Aftermarket electronic ignitions are almost always troublesome. As the ignition systems on old Fords of any vintage are "bulletproof" , if properly set up, I put them in the category of "if it ain't broke...."
supereal is offline   Reply With Quote
Old 08-17-2014, 08:11 PM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I picked up one of the old Mallory 8BA two part cap dist one time to use on my 59AB, I got the adapter to bolt on the front of the cam to drive the dist. Set the timing and it run fine until I rev it up fast and the timing would go out about 20*, reset the timing and the same thing happened again, I pulled the front cover and the small gear that drives the dist was slipping. I removed the gear and knurled the adapter and pressed the gear back on, never happeded again. Walt
Walt Dupont--Me. is offline   Reply With Quote
