Old 08-13-2014, 04:45 PM   #1
D. Jones
D. Jones's Avatar
Default AC fuel pump?
I have an AC EP11 electric fuel pump dated 8-80 I'd like to use as a a backup for the mechanical pump. I'm unsure if it is compatible with E-10 fuel. I assume it's a diaphragm type, but will have to admit I haven't opened it up to check. If I use it and the E-10 causes problems is there a readily available material I could use to replace the diaphragm and check valves, which are most likely rubber, that would work with E-10?
You thoughts are appreciated.
D. Jones is offline   Reply With Quote
