Old 08-09-2014, 05:04 AM   #1
nickair
nickair's Avatar
Default Water Pump Options
Just replaced my cracked 83 year old fan. When test running it for the new fan install inspection, I saw that my water pump housing was cracked on one side. Darn. Wish I would have seen that when it was all apart. :-)
Looking for advice on water pump options. Plan to replace the whole pump.
I did just add a thermostat when I replaced the fan and radiator hoses. Has a new radiator also.
1) Looking at ordering a leak-less water pump. Thoughts?
2) Is there a water pump impeller available with reduced size fins?
1931 Stock Tudor
Simplicity is the ultimate sophistication.
L.D.
I have 40 horses in the garage.
Only feed them when I want to take them out.
31 Model A Tudor 55B
Nick
nickair is offline   Reply With Quote
